Xbox 360 S Heat Sink Replacement
  1. Xbox 360 S Heat Sink Replacement, Top Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
    • Take care when removing the fan vent not to break any of the plastic clips.
  2. Xbox 360 S Heat Sink Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
    • Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
    • Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
    • Be sure to rotate the spudger far enough so that the plastic clips clear the silver rim of the top bezel.
  3. Xbox 360 S Heat Sink Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a metal spudger between the fan vent and top bezel along the left side of the console.
    • In the same manner described above, begin prying the left side of the top vent away from the top bezel.
    • Continue prying along the left side of the device, freeing all the clips on that side.
  4. Xbox 360 S Heat Sink Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the fan vent up from the freed left side to disengage the clips along the right side.
    • Remove the entire fan vent.
  5. Xbox 360 S Heat Sink Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In the following steps, you will be releasing the six clips highlighted in red.
    • Each clip can be undone by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
  6. Xbox 360 S Heat Sink Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the console so that the left case is facing toward you and the faceplate is facing toward the right.
    • Insert a metal spudger through the front-most slit on the left edge of the top bezel and between the bottom edge of the clip and the left case, as described above.
    • Simultaneously rotate the spudger away from the console and pull up on the top bezel to free the clip.
    • You will hear a "pop" signifying that the clip cleared its catch.
  7. Xbox 360 S Heat Sink Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the same method described above, free the two remaining clips along the left edge of the top bezel.
  8. Xbox 360 S Heat Sink Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the entire top panel with your hands, lift up the entire left edge high enough to rest the separated clips on top of the left case.
    • You may have to go back with a spudger and undo any clips that have re-attached.
    • The top panel will not come free of the console yet.
  9. Xbox 360 S Heat Sink Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
    • Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
    • While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
  10. Xbox 360 S Heat Sink Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In the same manner as described in the previous steps, release the middle and front clips along the right edge of the top panel.
  11. Xbox 360 S Heat Sink Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the top panel off the device.
    • You may have to go back with a spudger and undo any clips that have re-attached to the console.
  12. Xbox 360 S Heat Sink Replacement, Hard Drive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 S Heat Sink Replacement, Hard Drive: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 S Heat Sink Replacement, Hard Drive: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the Xbox 360 S so that the bottom of the console is facing toward you.
    • Push the latch holding down the hard drive cover to the left.
    • Pull the hard drive cover away from the console.
  13. Xbox 360 S Heat Sink Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly grasp the fabric tab labeled with the size of the hard drive (e.g. "250 GB") attached to the hard drive.
    • Pull the hard drive straight out of the console.
    • The fabric tab is attached to a catch further inside the hard drive housing. It will take some force to pull the hard drive out.
  14. Xbox 360 S Heat Sink Replacement, Bottom Panel: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In the following steps, you will remove the bottom vent.
    • It is attached to the bottom panel by the seven clips shown.
  15. Xbox 360 S Heat Sink Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the Xbox 360 S so that the hard drive port is facing up and the faceplate is facing to the left.
    • Insert a metal spudger between the black bottom vent and the silver rim of the bottom bezel, in the rear right corner of the vent.
    • Rotate the spudger away from the console, prying the vent up from the bottom bezel.
    • Be sure to rotate the spudger far enough so that the clips on the vent are lifted past the silver rim of the bottom bezel.
  16. Xbox 360 S Heat Sink Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In the same manner as described above, pry the two remaining clips on the bottom right edge.
    • All of the clips along both the right and front edge should now be free. If other clips have come undone as well, that is fine.
  17. Xbox 360 S Heat Sink Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the bottom vent by lifting it away from the bottom bezel.
  18. Xbox 360 S Heat Sink Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In the following steps, you will remove the bottom bezel, which is attached to the rest of the console by the four clips shown.
    • The clips shown in red can be detached by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
  19. Xbox 360 S Heat Sink Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a metal spudger through the slit near the rear left corner of the bottom bezel.
    • Rotate the spudger away from the device while lifting the rear bezel up with the other hand.
    • You may hear a "pop" signifying the clip has cleared its catch.
  20. Xbox 360 S Heat Sink Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a metal spudger through the left middle slit of the bottom bezel, and between the bottom edge of the clip and the left case.
    • Simultaneously pull the bottom bezel up and rotate the spudger away from the console to free the clip.
    • In a similar fashion, free the clip at the front of the bottom bezel's left edge.
    • The entire left side of the bottom bezel should now be free.
  21. Xbox 360 S Heat Sink Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the console around so that the faceplate is facing to the right and the right case is facing toward you.
    • Insert the spudger into the rear-most slit on the right edge of the bottom bezel, and wedge it behind the clip by pushing the spudger down while pushing the tip of the spudger against the right case.
    • Simultaneously release the clip and pull the bottom bezel up.
    • This clip is especially hard to remove. Some force will be required to insert the spudger correctly.
  22. Xbox 360 S Heat Sink Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This clip does not have a slit in the bezel to guide you. You can locate the clip by looking under the bezel near the hard drive slot.
    • Insert a spudger between the silver rim and bottom bezel directly above the clip shown.
    • Release the clip while pulling up on the bottom bezel.
  23. Xbox 360 S Heat Sink Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This clip is smaller than the others and should not be removed from above like the others.
    • Lift the left edge of the bottom bezel up enough to gain clearance.
    • Insert a metal spudger behind the left edge of the last clip, and push the clip away from the right case.
  24. Xbox 360 S Heat Sink Replacement, Left Case: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Opening your Xbox 360 any further will require breaking or removing the warranty sticker on the outer case. Your Microsoft warranty for any components not directly attached to the logic board will likely be voided by removing this seal.
  25. Xbox 360 S Heat Sink Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the console right-side up, with the faceplate facing toward you.
    • Locate the two clips connecting the right and left case along the top edge of the console, behind the Wi-Fi card.
    • While pushing the left and right case away from each other with one hand, pry the clips away from the case with a metal spudger.
  26. Xbox 360 S Heat Sink Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue to hold the two cases apart to prevent the clips reattaching.
    • Insert a spudger between the right and left cases to hold them separate while you work elsewhere.
  27. Xbox 360 S Heat Sink Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the Xbox over so the faceplate is facing left, and the left case is facing toward you.
    • While pushing the left and right cases apart with one hand, free one clip located beside the hard drive slot.
  28. Xbox 360 S Heat Sink Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue to hold the cases apart to prevent the clips from reattaching.
    • Place another spudger between the left and right cases directly below the clip.
  29. Xbox 360 S Heat Sink Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat edge of a metal spudger between the left and right cases where the warranty sticker used to be.
    • Pry the left case upwards to form a gap between the two cases, and slide the spudger in toward the left case.
    • Rotate the spudger upward to release the last clip.
    • The spudgers holding the top and bottom clips apart may be removed.
  30. Xbox 360 S Heat Sink Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Release one clip in the front left corner of the top edge securing the left case to the faceplate.
  31. Xbox 360 S Heat Sink Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the console over so the bottom is facing upward.
    • Release one clip in the front left corner of the bottom edge securing the left case to the faceplate.
    • Rotate the left case away from the device to release the last two inner clips.
    • Remove the left case.
  32. Xbox 360 S Heat Sink Replacement, Faceplate: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement, Faceplate: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the console right-side-up, with the faceplate facing forward.
    • Release the clip near the front right corner of the top edge securing the right case to the faceplate.
  33. Xbox 360 S Heat Sink Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the console over, so that the bottom is facing upward, and the faceplate is facing forward.
    • Release the clip in the bottom right corner of the top edge securing the right case to the front case.
  34. Xbox 360 S Heat Sink Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the left edge of the faceplate upward to release the last two clips securing the faceplate to the right case.
    • Detach the faceplate from the rest of the device.
    • The faceplate is still attached to the console by a thin ribbon cable. Do not attempt to completely remove the faceplate yet.
  35. Xbox 360 S Heat Sink Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:035crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger or fingernail, lift the clear blue tab away from the connector.
    • Slide the locking tab on the power switch board cable connector toward the top of the console.
    • The locking tab will only move about 2 mm.
    • Pull the power switch cable straight out of the connector.
    • The faceplate is now free of the rest of the console.
  36. Xbox 360 S Heat Sink Replacement, RF Module: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5.6 mm T8 Torx screws securing the RF module to the metal case.
  37. Xbox 360 S Heat Sink Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The RF module is still connected to the Xbox by a large USB-type connector.
    • Pull the board directly away from the Xbox to remove it.
  38. Xbox 360 S Heat Sink Replacement, Wi-Fi Board: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 S Heat Sink Replacement, Wi-Fi Board: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 S Heat Sink Replacement, Wi-Fi Board: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the single T10 Torx screw holding in the wireless card.
    • Pull the Wi-Fi Board out of the console.
  39. Xbox 360 S Heat Sink Replacement, Right Case: crwdns2935265:039crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the large white sticker from the metal frame to expose a screw.
    • This is a tamper-evident sticker, but don't worry—Microsoft can't legally void your warranty as long as you don't damage anything. Have fun!
  40. Xbox 360 S Heat Sink Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 55.5 mm T10 Torx screws securing the right case to the metal frame.
  41. Xbox 360 S Heat Sink Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the Xbox over so the right case is facing up.
    • Lift the right case off by its metal framework.
  42. Xbox 360 S Heat Sink Replacement, Optical Drive: crwdns2935265:042crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement, Optical Drive: crwdns2935265:042crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the optical drive data cable from the back of the optical drive.
    • Disconnect the power cable from the back of the optical drive.
  43. Xbox 360 S Heat Sink Replacement: crwdns2935265:043crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the optical drive out of the Xbox.
  44. Xbox 360 S Heat Sink Replacement, Hard Drive Bracket: crwdns2935265:044crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the console over so that the metal case is facing up.
    • Remove the single 11.3 mm gold T10 Torx screw from the hole marked "G."
  45. Xbox 360 S Heat Sink Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the fan duct off the fan.
    • There is a locator peg underneath the fan duct (top right corner of the fan duct as viewed in the pictures). When reinstalling look down the screw hole to aid alignment.
  46. Xbox 360 S Heat Sink Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:046crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single 9.2 mm T10 Torx screw securing the hard drive cable connector to the plastic bracket.
    • Lift the hard drive cable connector off the hard drive bracket.
  47. Xbox 360 S Heat Sink Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 11.3 mm T10 Torx screw holding the hard drive bracket to the metal frame, near the DC-In port.
  48. Xbox 360 S Heat Sink Replacement: crwdns2935265:048crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the hard drive bracket out of the metal frame.
  49. Xbox 360 S Heat Sink Replacement, Fan: crwdns2935265:049crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the fan cable by pulling its connector off the logic board.
  50. Xbox 360 S Heat Sink Replacement: crwdns2935265:050crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:050crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:050crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two 11.7 mm Phillips screws securing the fan to the heat sink in the bottom right and top left corners of the fan.
    • Remove the fan from the logic board assembly.
  51. Xbox 360 S Heat Sink Replacement, Motherboard: crwdns2935265:051crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are a total of 10 screws holding the logic board assembly to the metal case:
    • Five 11.3 mm silver T10 Torx screws, in the holes marked "M", "N", "P", "R", and "T".
    • Four 5.6 mm black T9 Torx screws in the holes marked "D", "E", "J", and "K".
    • A single 11.3 mm gold T10 Torx screw in the hole marked "A".
  52. Xbox 360 S Heat Sink Replacement: crwdns2935265:052crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:052crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the optical drive retaining bracket off the logic board.
  53. Xbox 360 S Heat Sink Replacement: crwdns2935265:053crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:053crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the heat sink with one hand, and hold the metal frame with the other.
    • Lift the logic board assembly out of the metal frame.
    • Removing the logic board assembly will require some force.
  54. Xbox 360 S Heat Sink Replacement, Heat Sink: crwdns2935265:054crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement, Heat Sink: crwdns2935265:054crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Flathead 1.5 mm Screwdriver
    $5.49
    • Turn the logic board assembly over to access the heat sink's x-clamp.
    • To avoid ESD damage, be sure to lay your logic board on a soft, static free surface during service.
    • The logic board is very sensitive to impact and scratching. Be sure to not let the screwdriver slip and damage the logic board.
    • Starting at the front left corner of the x-clamp, insert a 1.5 mm flathead screwdriver between the heat sink's peg and the x-clamp's hook.
    • If you're worried about scratching the logic board, insert a spudger or thin screwdriver down through one of the holes in the x-clamp, in the gap just inside the screw post. Pry outward to release the x-clamp. Repeat for the opposite arm.
  55. Xbox 360 S Heat Sink Replacement: crwdns2935265:055crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:055crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the logic board 90 degrees clockwise.
    • In the same manner described above, release the rear right hook of the x-clamp.
  56. Xbox 360 S Heat Sink Replacement: crwdns2935265:056crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:056crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the logic board 180 degrees counter-clockwise.
    • In the same manner described above, release the rear left hook of the x-clamp.
  57. Xbox 360 S Heat Sink Replacement: crwdns2935265:057crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:057crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the x-clamp off the back of the logic board.
  58. Xbox 360 S Heat Sink Replacement: crwdns2935265:058crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 S Heat Sink Replacement: crwdns2935265:058crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using one hand to hold the heat sink in place, carefully turn the logic board over.
    • Lift the heat sink off of the logic board.
    • Before reinstallation, follow our thermal paste guide to replace the thermal compound between the heat sink and processor.
crwdns2935229:072crwdne2935229:0
David Hodson
crwdns2935283:004/13/10crwdne2935283:0
153,433 crwdns2915208:0crwdne2915208:0
crwdns2935297:0127crwdne2935297:0
crwdns2947412:016crwdne2947412:0
This is a great guide. Thank you for taking the time to make it.
Brian Douglas - crwdns2934203:0crwdne2934203:0
Intercooler guys, purchase an intercooler and save yourself from this hassle
haywirestudent7 - crwdns2934203:0crwdne2934203:0
I had problems getting the x-bracket off the back (step 54-57).
I found this video using a pair of needle nose pliers that helped me immensely with this step:
https://www.youtube.com/watch?v=dDAW_tRi...
Matt Bailey - crwdns2934203:0crwdne2934203:0
I think we all ended up finding that video...
rasskipper -
Thank you for taking the time to make this very instructional guide
Michael Wiley - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 26
crwdns2936753:07crwdne2936753:0 107
crwdns2936753:030crwdne2936753:0 532
crwdns2942667:0crwdne2942667:0 96,279
