There is no such thing as too much hard drive space, and nothing more frustrating than too little. This guide will show you how to replace your Xbox 360 S hard drive.
Push the latch holding down the hard drive cover to the left.
Pull the hard drive cover away from the console.
Firmly grasp the fabric tab labeled with the size of the hard drive (e.g. "250 GB") attached to the hard drive.
Pull the hard drive straight out of the console.
If i buy a new xbox 360 and replace the hardrive inside with my own, will i have my account and saves? or will i have to recover my account and start over?
You will still have your saves and account if you replace your hard drive in the new xbox
hola tengo un disco de laptop y quiero ponerle 100 juegos como puedo hacer la xbox me reconose el disco y todo lo configuro pero cuando conecto a mi pc para pasar los juejosel emulador no me deja
My fabric was accidentally ripped off years ago. What do I do?
Stick another bit on there
crwdns2935229:098crwdne2935229:0
crwdns2944067:04crwdne2944067:0
do you have to transfer the OS? or data? if so what utility is used? do you need a data transfer cable?
Can I just add an external drive to supplement the existing HDD?
no the os is on the internal drive all the hard drive is doing is adding more storge space
My hardrive says its unformated but its not and i dont want to loose content
Javier Eduardo Pacheco Hazim - crwdns2934203:0crwdne2934203:0
Can I take the external out of the little black cover?
