This guide is for Xbox 360 Wireless Racing Wheel that experiences erratic steering behavior, whereby the wheel is not moving consistently with the input, or jumping all over the place. This is easiest to view the problem in a Windows PC with the wireless receiver, via the gamepad properties where you can compare your wheel motion to what the computer sees. If you see the output jumping all over the place, this is an indication that the variable resistance pot (potentiometer) has gotten dirty or is broken.
Remove 8 screws from the base (two are covered by the sticker), using a TX10 security screwdriver (i.e. with the security hole at the top)
Remove the additional 8 screws from the back of the wheel assembly, again, using the TX10 security screwdriver.
Identify the small beige panel with the pot on it. Place the steering wheel in the middle position and note the pot orientation (flat area of white guide will be towards to left.
Disconnect the plug.
Using a TX10 screwdriver, remove the panel, and place it on your workbench.
Potentiometer is a 10 k-ohm, and it is difficult to find a replacement, but it might simply need to be cleaned.
Note that the rivets may impede the cover from coming up, so use the side that has the most clearance from the rivet. Then using two jewelers screwdrivers, carefully lift at one corner while carefully bending the tab on that side. Twist just enough to allow the cover of the pot to get past the tab.
Once the pot is clear of the tab, use a small pair of pliers to gently extract the top portion of the pot.
Place the cover of the pot upside-down on your workbench
Using a cotton swab moistened with alcohol, gently clean the pot top cover traces. Notice the grey residue on the swab.
Remove the wiper from the pot body. Note: the wiper is extremely small and thin, so be extremely gentle.
Once on the workbench, use a clean swab moistened with alcohol, and lightly clean the wiper contacts, applying very little pressure so as not to change the shape of the wipers.
Using a screwdriver down the middle of the board for alignment, drop the wiper back into the body of the pot.
Align the pot cover into the grooves at the back (the side opposite from the connector), the gently press down until it clicks into the tabs. Note that the metal extensions of the pot cover interfered with the rivets slightly, and a screwdriver was used to get past the rivets.
Re-install the pot board with the 2 TX10 screws.
Reconnect the connector.
Re-assemble the bottom cover and base.
To reassemble your device, follow these instructions in reverse order. Do not overtorque the screws as they are into a plastic casing and will strip easily.
where can you find replacement pots as the one on my wheel has gone
like the traces on mine are clean but too worn to actually work anymore
doubl99 -
I did a search on the internet (by picture and by text) and I was unable to find an exact replacement. I see two options: pull a working pot from another used wheel, or source a generic 10.5 kilo-ohm* pot that is similar, and mechanical bind (glue?) the shaft into the potentiometer's hole. Note: 10.5 kilo-ohm is what I measured at full deflection, so most likely, it is a 10.0 kilo-ohm pot.
