Xbox 360 Racing Wheel - Fix variable resistance pot
  1. Xbox 360 Racing Wheel - Fix variable resistance pot, Remove the base: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 8 screws from the base (two are covered by the sticker), using a TX10 security screwdriver (i.e. with the security hole at the top)
  2. Xbox 360 Racing Wheel - Fix variable resistance pot, Remove the steering wheel back panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the additional 8 screws from the back of the wheel assembly, again, using the TX10 security screwdriver.
  3. Xbox 360 Racing Wheel - Fix variable resistance pot, Remove the potentiometer: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 Racing Wheel - Fix variable resistance pot, Remove the potentiometer: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 Racing Wheel - Fix variable resistance pot, Remove the potentiometer: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Identify the small beige panel with the pot on it. Place the steering wheel in the middle position and note the pot orientation (flat area of white guide will be towards to left.
    • Disconnect the plug.
    • Using a TX10 screwdriver, remove the panel, and place it on your workbench.
  4. Xbox 360 Racing Wheel - Fix variable resistance pot, Remove Pot Top Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 Racing Wheel - Fix variable resistance pot, Remove Pot Top Cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 Racing Wheel - Fix variable resistance pot, Remove Pot Top Cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Potentiometer is a 10 k-ohm, and it is difficult to find a replacement, but it might simply need to be cleaned.
    • Note that the rivets may impede the cover from coming up, so use the side that has the most clearance from the rivet. Then using two jewelers screwdrivers, carefully lift at one corner while carefully bending the tab on that side. Twist just enough to allow the cover of the pot to get past the tab.
    • Once the pot is clear of the tab, use a small pair of pliers to gently extract the top portion of the pot.
    • Place the cover of the pot upside-down on your workbench
  5. Xbox 360 Racing Wheel - Fix variable resistance pot, Use Isopropyl alcohol to clean the pot material: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 Racing Wheel - Fix variable resistance pot, Use Isopropyl alcohol to clean the pot material: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a cotton swab moistened with alcohol, gently clean the pot top cover traces. Notice the grey residue on the swab.
  6. Xbox 360 Racing Wheel - Fix variable resistance pot, Remove the pot wiper and clean: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox 360 Racing Wheel - Fix variable resistance pot, Remove the pot wiper and clean: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wiper from the pot body. Note: the wiper is extremely small and thin, so be extremely gentle.
    • Once on the workbench, use a clean swab moistened with alcohol, and lightly clean the wiper contacts, applying very little pressure so as not to change the shape of the wipers.
  7. Xbox 360 Racing Wheel - Fix variable resistance pot, Re-install pot wiper and pot cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox 360 Racing Wheel - Fix variable resistance pot, Re-install pot wiper and pot cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox 360 Racing Wheel - Fix variable resistance pot, Re-install pot wiper and pot cover: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a screwdriver down the middle of the board for alignment, drop the wiper back into the body of the pot.
    • Align the pot cover into the grooves at the back (the side opposite from the connector), the gently press down until it clicks into the tabs. Note that the metal extensions of the pot cover interfered with the rivets slightly, and a screwdriver was used to get past the rivets.
    • Re-install the pot board with the 2 TX10 screws.
    • Reconnect the connector.
    • Re-assemble the bottom cover and base.
To reassemble your device, follow these instructions in reverse order. Do not overtorque the screws as they are into a plastic casing and will strip easily.
Michel_K17
crwdns2935283:007/06/24crwdne2935283:0
593 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 197
