Use this guide if the connections in the back of your Xbox 360 E aren't working. Replacing the motherboard requires a little more time than replacing other parts of your Xbox.
crwdns2935267:0crwdne2935267:0Spudger$2.99
Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
Pull the top panel off.
Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
Slide the spudger along the crevice to separate the grated face and the top body.
Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate.
Slide the spudger along the crevice, going completely about the perimeter of the bottom panel.
Pull the bottom panel off.
In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go.
Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands.
Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
My actual disk tray came off the track looking into the best way to repair it
Flip the Xbox so the opposite side is towards you. Make sure to keep the separation open.
Locate the other clip and insert the spudger to remove it.
Continue to run the spudger along the crease to release any further clips that may still be attatched.
Now that the front panel has been released from its clips you can pull off the front panel.
Find the brown section where the ribbon cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon.
Looking at the body of the device, locate the green panel to the right of the CD drive.
Remove the two 6 mm screws located on the top left and middle right with a T8 Torx screwdriver.
Grip the middle of the green board and gently pull it out.
Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
Firmly grip the green Wi-Fi card and pull it out of the Xbox.
On that wifi card there is a little port that you can plug and old router antena into. Any idea what its called?
Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device.
Lift the bottom body slightly away from the core at a 45 degree angle.
Rotate the Xbox so you are now looking at the back of the device.
Remove the sticker from the back of the Xbox.
Turn the Xbox to the left to locate the clip holding the body together.
With a spudger, press up on the clip like a latch. Move to the far end to undo the other clip the same way.
Push the spudger into the crevice. Slide the spudger along the vertical crevice to detach the last clip. The bottom body should slide off after this.
Remove the five long black 55 mm screws labeled C2-5 and C7 with a T9 Torx screwdriver.
Carefully flip the device and pull off the body by lifting from the metal section that is attached to the plastic exterior.
C1 - C5 screws
And not T9 - the're T10 screws
Missing some steps here…. Where are the clips holding the sides together? To go straight from “Remove bottom cover” to “Device is apart” is a bit… lacking.
Yes, Aksel Barnes is correct. There are missing pictures and steps showing the removal of the plastic exterior from the metal section.
another "manual" missing the hardest steps
Just wanted to share my experience: after you "spudge" off the top and bottom you have to "spudge" off the front as well. Then you can follow the rest of the steps
Use your fingers to unplug the blue ribbon cable from the CD drive.
Note: The ribbon cable connected to the CD drive can be in the color red (as it was on my board). Just make sure the other end is connected to the motherboard to be sure.
Como destrava a gaveta do cd
Valtecir César Melo Martins - crwdns2934203:0crwdne2934203:0
Use tweezers to unplug the blue and pink wires.
Lift the front end of the CD drive and take it out.
Just note that you will have to swap the PCB inside the disc drive. If you do not go through with this the game will not start.
You do also require some soldering skills as the wires for the motor and sensor for the disc tray are soldered to the PSB.
From the bottom of your Xbox, take your T9 torx screwdriver and take out all of the 11 mm screws labelled B1-7
Don't forget a screw on the side of the Xbox next to the power plug.
They’re actually T10
The screw B1 is not shown it is written on the board and is located at the bottom right of the picture. The red circle mark doesn't show a screw.
Flip the Xbox over and take out the heat sink plastic shield.
Unplug the red cable.
Unplug the blue cable.
Take the hard drive assembly by the long plastic arm and lift the entire thing out.
Flip the Xbox to the back and take your T10 torx screwdriver and take out the last four 6 mm screws labelled A1-4.
Back to the top of the Xbox, take out the metal and plastic insert.
As the motherboard comes up, switch to the left side and continue pulling the motherboard up.
Once that side of the motherboard is out, lift the rest of the motherboard away from the metal body.
crwdns2935229:036crwdne2935229:0
crwdns2944067:04crwdne2944067:0
Where can I get the motherboard?
Need a motherboard.....
How did you go finding one ? , I gotta get one I think , any chance u could get hold of me by email or I'm on fb ? , just wanna ask you about something with xbox memory n error cap
Would have been nice to include the heatsink removal procedure even if it is similar to the original 360. Also I have never had extra screws left over, yet I have 2 phillips screws left over which are mentioned nowhere in this guide. From no point of the teardown process could I find where they came from.
