This guide will help the owner of a Kitchen Gourmet XQ-673H replace the power cord.
Turn the Kitchen Gourmet upside down.
Using a phillips #1 screwdriver, remove the six 10mm screws found on the bottom of the device.
Remove the bottom cover.
Using a Phillips #1 screwdriver, unscrew the 11mm screws.
Remove the plastic bar that is holding the Power Cord down.
Using scissors, carefully cut the zip tie.
Careful not to cut the Power Cord.
Using small needle nose pliers, gently squeeze the side so it allows the metal clamp to open up.
Gently pull off the plastic cover.
Repeat this step with the other plastic cover.
Remove the Power Cord from the device.
