Replace Memory Module
With the computer still turned over, loosen the captive screw on the memory module cover and slide the cover toward the back of the computer to remove it.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
Remove the module from the connector on the system board.
Align the notch on the edge of the memory module connector with the tab in the connector on the system board, and slide the module firmly into the connector at a 45-degree angle.
Rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
Replace the memory cover. Align the notches in the cover with the tabs on the base, slide the cover toward the front of the computer, and tighten the captive screw.
