This guide will walk you through the steps to disassemble the XMAX V3 Pro, providing a detailed look at its internal components.
Remove the battery from the device
Apply heat from a hair dryer to help soften the glue
Use a spudger to pry off bottom cover
Remove four PH000 screws
Remove plastic cover
Use your thumb to apple pressure in the direction of the arrow
The entire assembly should slide out of the metal case
Remove both P00 Screws
Use a spudger to remove the vibration motor and spring
The rubber gasket that can be seen better in step 11 stops air from entering the heating assembly from the motherboard area and only allows it to be drawn in the the side perforations.
Air enters though the area within the red square and then goes though the hole within the red circle
Use your thumb to push in the gold contact
Use a spudger to completely remove the gold battery contact from case
Remove rubber gasket, simply slide it down the heater assembly
Remove four P000 screws
would it be possible to provide a clearer view of the pcb in higher resolution?
Desolder positive battery terminal and both heater wires
Desolder both temperature probe wires
Use your fingers to pull off the heater assembly
Remove both P000 screws
Pull out positive battery terminal assembly
Use a nail or spudger to remove the heater core from the outside housing
I wonder how the air gets inside the heater core, it does not seem to have any holes!
