X230T RAM Replacement
David Newberry
crwdns2944109:0crwdnd2944109:0David Newberrycrwdnd2944109:0crwdnd2944109:0crwdnd2944109:0crwdne2944109:0
crwdns2944111:0Huk 20, 2017crwdne2944111:0
crwdns2931287:05crwdne2931287:0
crwdns2937585:0crwdne2937585:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
Both of the X230T's RAM slots are located on the bottom of the laptop, underneath a compartment held in by two screws.
This laptop is compatible with DDR3 SODIMM or DDR3L SODIMM running at 1333 MHz or 1600 Mhz.
  • Phillips #1 Screwdriver
  • Spudger
    Spudger (Small)
crwdns2944105:0crwdne2944105:0
  1. X230T RAM Replacement, Removing the battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start by removing the battery from the laptop. The battery should be removed to prevent damaging the motherboard when the RAM is installed and removed.
    • Slide the latch on the left to the left, and hold the other latch on the right to the right.
    • Slide out the battery, it should come out effortlessly.
  2. X230T RAM Replacement, Removing the RAM cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Undo the two screws that are circled, then, pry the RAM cover off by placing your finger nail or a spudger between the laptop and the RAM cover and puling up.
  3. X230T RAM Replacement, Removing RAM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 X230T RAM Replacement, Removing RAM: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 X230T RAM Replacement, Removing RAM: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two clips from the RAM by pulling them slowly in the direction shown by the red arrows. When both clips are released, the RAM will lift up at a 45 degree angle (picture 2).
    • Once the RAM is at the angle as shown in picture 2, remove the RAM by pulling it out of the computer, as shown by the orange arrow.
    • If required, repeat the procedure for the other RAM module. The steps are the same.
  4. X230T RAM Replacement, Installing RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 X230T RAM Replacement, Installing RAM: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 X230T RAM Replacement, Installing RAM: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To install the RAM, insert the new RAM with the notch on the RAM lining up to the notch on the slot. Slide the RAM in on a 45 degree angle as shown in picture 1.
    • Firmly push down the RAM until it is locked in place by the clips on either side. The clips will move around the RAM when the RAM is being inserted.
    • Put on the cover with the clips going in to the bottom edge of the cover first, then, tighten up the screws on the RAM cover.
    • Install the battery in to the computer, making sure the locking clips are engaged, and power the computer on.
    • Check the BIOS or your operating system to verify the RAM is working.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
David Newberry
crwdns2935283:004/20/17crwdne2935283:0
385 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 1,059
