Follow this guide to replace the rotating brush from your Wyze WVCR200s robot vacuum. The rotating brush is a part of the vacuum that will need to be taken out to be cleaned regularly.
Flip the vacuum upside down so the bottom is facing up.
Pinch the blue tabs below the rotating brush towards each other.
Lift the plastic housing surrounding the rotating brushing straight up, and the remove it from the vacuum.
To remove the rotating brush, lift one end of the brush upwards, and remove.
