The Wyze Cam V2 comes with a charging port that allows you to power your device. If your charging port starts having charging problems you might need to replace it. This guide will help you through the steps of replacing it.
Open up the camera stand to expose the bottom plate of the camera.
Remove two 4 mm silver screws using the Phillips #0 screwdriver.
Using the iFixit opening tool, carefully pry open the bottom plate to gain access to the camera's internals.
Open up the back panel using the iFixit opening tool and unclip the panel from the rest of the device.
crwdns2935267:0crwdne2935267:0Tweezers$3.99
Using the angled slim tweezers, disconnect the cord and pull it gently off of the motherboard.
Remove the single 6 mm screw located deep inside the device using a Phillips #000 screwdriver.
Carefully remove the motherboard from the device.
Remove the remaining two 6 mm screws from the motherboard with a Phillips #0 screwdriver.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using the precision tweezers, detach the charging port’s motherboard from the camera’s motherboard.
Desolder the iron piece holding the charging port in place.
Carefully detach the charging port from the motherboard.
