Place CHiP on its back so that its stomach is facing you.
There are three small hex screws connecting the battery to CHiP. Remove all screws with a hex screwdriver and remove battery casing.
Once the top face of the battery is off, you will see a small rectangular box that the batteries are inside. There are 4 Phillips head screws in the box. Remove all screws with a Phillips head screwdriver.
what is the purpose for removing the battery if you cannot buy a new one?
I need a new batties in my chip dog. Please tell me we're can u get it from and bed stand
do i need new one?. I have this but after remove the battery what next, not very helpful
Once the battery is removed from body, the battery should be connected by a red and black wire. There is a red rectangular connector that easily pulls apart. Pull apart the red rectangular connector.
Twist grey wheel cap in counter-clockwise rotation.
Pull and remove wheel.
можно не отключать.а в каком положении должны быть инкодеры при таком положении лап? при замене шестеренок, как правильно выставить нулевое значение инкодера?
Why do you have to disconnect the battery before changing the wheel? Can you not just turn off the power and change it?
зачем снимать акб?
замена или снятие колес происходит при простом отключении устройства обычным выключателем.
Heads up it is really hard to turn
