WowWee CHiP Robot Dog Ear Replacement
Place CHiP on its back so that its stomach is facing you.
There are three small hex screws connecting the battery to CHiP. Remove all screws with a hex screwdriver and remove battery casing.
Once the top face of the battery is off, you will see a small rectangular box that the batteries are inside. There are 4 Phillips head screws in the box. Remove all screws with a Phillips head screwdriver.
what is the purpose for removing the battery if you cannot buy a new one?
I need a new batties in my chip dog. Please tell me we're can u get it from and bed stand
do i need new one?. I have this but after remove the battery what next, not very helpful
Once the battery is removed from body, the battery should be connected by a red and black wire. There is a red rectangular connector that easily pulls apart. Pull apart the red rectangular connector.
Remove the 4 Phillips screws shown.
Pull up top part of toy and remove the connecting wires.
Unscrew the 2 Phillips head screws. CHiP should be viewed as seen in the third picture.
Remove the 4 Phillips screws to separate the head from the body.
Remove the 4 Phillips screws on back of the head, and pull off the casing for the back of the head.
Unscrew the screw on the ear with a Phillips screwdriver, and pull off the plastic connector. Remove the ear from head.
It’s almost a disassembly, probably quite hard to do. I did disassemble a MiPosaur, but some parts broke off. (!!!)
