Occasionally the dryer air may be muffled or too hot due to a clogged filter, and so cleaning or replacement may be necessary. Disassembly of the device requires a special bit for removal of tamper-proof screws.
In order to change the air filter, start with the removal of the outer metal casing. Use the appropriate security bit.
Using the special bit, remove the large screws at the bottom of the casing.
To remove the case, lift the indicated spot with your hands.
To access both filters, unscrew all three 1/2" Ph2 screws.
Gently pull the plate away from the black, coarse filter.
After removing the small grey filter, pull on the black, ring-shaped filter to remove it.
