Wolf Gourmet WGTR102S Slide Assist Plunger Replacement
  1. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
  2. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
  3. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the crumb collector located on the bottom of the toaster.
  4. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
  5. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
  6. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the final 8mm screw in the slide lever.
    • The lever can now pull away from the entire unit.
  7. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove toaster's outer shell by lifting straight up.
    • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
  8. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
    • Remove the outer shell from the device.
  9. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement, Slide Assist Plunger: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top panel by bending the tabs on each side straight up.
  10. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 8mm screws on the bottom of the plunger using a Tri-point Y1 screwdriver.
  11. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plunger from the device.
Ryan Funchess
crwdns2935283:004/19/18crwdne2935283:0
715 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S22-G5, Maness Spring 2018 crwdns2935289:0Cal Poly, Team S22-G5, Maness Spring 2018crwdne2935289:0
CPSU-MANESS-S18S22G5
Where does one get a new plunger for the replacement?
hsernaker - crwdns2934203:0crwdne2934203:0
yes, where does one get a new pludger?
hiyar124 - crwdns2934203:0crwdne2934203:0
Has anyone found a source for the WOLF toaster plunger?
Rick Guest - crwdns2934203:0crwdne2934203:0
Any pointers on where to find Wolf replacement parts ?
Stefano Concina - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,419
