Wolf Gourmet WGTR102S Electrical Connection Replacement
  1. Wolf Gourmet WGTR102S Electrical Connection Replacement, Outer Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
  2. Wolf Gourmet WGTR102S Electrical Connection Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
  3. Wolf Gourmet WGTR102S Electrical Connection Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the crumb collector located on the bottom of the toaster.
  4. Wolf Gourmet WGTR102S Electrical Connection Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
  5. Wolf Gourmet WGTR102S Electrical Connection Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
  6. Wolf Gourmet WGTR102S Electrical Connection Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the final 8mm screw in the slide lever.
    • The lever can now pull away from the entire unit.
  7. Wolf Gourmet WGTR102S Electrical Connection Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove toaster's outer shell by lifting straight up.
    • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
  8. Wolf Gourmet WGTR102S Electrical Connection Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wolf Gourmet WGTR102S Electrical Connection Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
    • Remove the outer shell from the device.
  9. Wolf Gourmet WGTR102S Electrical Connection Replacement, Electrical Connection: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the ground wire using a Tri-point Y1 screwdriver. It is secured with an 8mm screw.
    This skips one step. Loosening the circuit panel and pulling aside after removing the two screws at bottom
    Valentino - crwdns2934203:0crwdne2934203:0
  10. Wolf Gourmet WGTR102S Electrical Connection Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use pliers to pull apart the three electrical connectors pictured in the graphic.
  11. Wolf Gourmet WGTR102S Electrical Connection Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the electrical connectors.
    Would love to know how to remove the cord from the unit. Easy up until this point, then it is near impossible to get the cord out to replace. Also finding an equivalent cord is difficult as WOLF will not release part information.
    Where can we get new electric connectors? Will Wolf provide these if unit is only 7-months old?
    Kurt Lindahl - crwdns2934203:0crwdne2934203:0
Ryan Funchess
crwdns2935283:004/19/18crwdne2935283:0
715 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S22-G5, Maness Spring 2018 crwdns2935289:0Cal Poly, Team S22-G5, Maness Spring 2018crwdne2935289:0
CPSU-MANESS-S18S22G5
Ryan Funchess
Thank you for you work on this toaster. My customer is happy.
Adam Hunsinger - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 934
