Wolf Gourmet WGBL100S Power Cord Replacement
  1. Wolf Gourmet WGBL100S Power Cord Replacement, Power Cord: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wolf Gourmet WGBL100S Power Cord Replacement, Power Cord: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the bottom of the blender facing up, use a Phillips #2 screwdriver to remove the 4, 1/2 inch long screws in the corners of the device.
    • Ensure the blender is off and unplugged before starting.
  2. Wolf Gourmet WGBL100S Power Cord Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wolf Gourmet WGBL100S Power Cord Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a metal spudger, pry up one side of each of the rubber feet.
    • Note that one side of each foot is glued down; pry up the non-glued side.
  3. Wolf Gourmet WGBL100S Power Cord Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the same Phillips #2 screwdriver, unscrew the 1/2 inch long screw under each of the feet.
  4. Wolf Gourmet WGBL100S Power Cord Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wolf Gourmet WGBL100S Power Cord Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull off the base and remove the plastic housing underneath.
  5. Wolf Gourmet WGBL100S Power Cord Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wolf Gourmet WGBL100S Power Cord Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the underside of the base, unscrew the three 3/8" long screws on the plastic piece holding the power cord in place using a Phillips #1 screwdriver.
    • Pull the plastic cover off.
  6. Wolf Gourmet WGBL100S Power Cord Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a wire cutter, cut the three wires of the power cord.
  7. Wolf Gourmet WGBL100S Power Cord Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wolf Gourmet WGBL100S Power Cord Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the cut power cord through the base.
    • Then thread the replacement cord back through and re-attach the plastic cover.
  8. Wolf Gourmet WGBL100S Power Cord Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wolf Gourmet WGBL100S Power Cord Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wolf Gourmet WGBL100S Power Cord Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Strip about an inch of insulation off of the snipped power cord and your replacement cord.
    • Twist each strand of wires together to keep them neat.
  9. Wolf Gourmet WGBL100S Power Cord Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wolf Gourmet WGBL100S Power Cord Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Twist together the wires from the replacement cord to the wires still attached to the blender.
    • Solder the connection if possible.
  10. Wolf Gourmet WGBL100S Power Cord Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wolf Gourmet WGBL100S Power Cord Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wrap all the connections in electrical tape or heat shrink tubing.
To reassemble your device, follow steps 1-5 in reverse order.
Cole Gillespie
crwdns2935283:004/19/18crwdne2935283:0
476 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S25-G16, Maness Spring 2018 crwdns2935289:0Cal Poly, Team S25-G16, Maness Spring 2018crwdne2935289:0
CPSU-MANESS-S18S25G16
crwdns2942667:0crwdne2942667:0 392
