Wolf Gourmet WGBL100S O-ring Replacement
  1. Wolf Gourmet WGBL100S O-ring Replacement, Blender Blades: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip over the pitcher to expose the base of the blade assembly.
    • Using the H4.0 Allen key from the 54 bit driver kit, attached to an impact driver, remove the socket head cap screw from the drive coupling.
    • Apply a solvent to remove adhesive if necessary.
  2. Wolf Gourmet WGBL100S O-ring Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a pair of pliers, pull of the drive shaft coupling.
  3. Wolf Gourmet WGBL100S O-ring Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wolf Gourmet WGBL100S O-ring Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a flat head screwdriver and a mallet, bend down the two tabs holding the large nut.
  4. Wolf Gourmet WGBL100S O-ring Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the nut using a crescent wrench.
  5. Wolf Gourmet WGBL100S O-ring Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the blade assembly into the jar.
    • Remove the blades from the device.
    • Be careful not to cut yourself when handling the blades.
  6. Wolf Gourmet WGBL100S O-ring Replacement, O-Ring: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wolf Gourmet WGBL100S O-ring Replacement, O-Ring: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to pull off the o-ring.
    • Be careful not to cut yourself while handling the blender blades.
Luke Kutz
crwdns2935283:004/19/18crwdne2935283:0
354 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S25-G16, Maness Spring 2018 crwdns2935289:0Cal Poly, Team S25-G16, Maness Spring 2018crwdne2935289:0
CPSU-MANESS-S18S25G16
crwdns2942667:0crwdne2942667:0 443
