If your blender is leaking or making strange noises, consider replacing the O-ring.
Flip over the pitcher to expose the base of the blade assembly.
Using the H4.0 Allen key from the 54 bit driver kit, attached to an impact driver, remove the socket head cap screw from the drive coupling.
Using a pair of pliers, pull of the drive shaft coupling.
Using a flat head screwdriver and a mallet, bend down the two tabs holding the large nut.
Remove the nut using a crescent wrench.
Push the blade assembly into the jar.
Remove the blades from the device.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to pull off the o-ring.
