If your blender is not chopping food correctly, consider replacing the blades. The blades can be very sharp, so please take caution when proceeding with this guide.
Flip over the pitcher to expose the base of the blade assembly.
Using the H4.0 Allen key from the 54 bit driver kit, attached to an impact driver, remove the socket head cap screw from the drive coupling.
Using a pair of pliers, pull of the drive shaft coupling.
Using a flat head screwdriver and a mallet, bend down the two tabs holding the large nut.
Remove the nut using a crescent wrench.
Push the blade assembly into the jar.
Remove the blades from the device.
Can anyone advise where to buy replacement blade
