Withings Smart Body Analyzer Motherboard Replacement
  1. Withings Smart Body Analyzer Motherboard Replacement, Withings Smart Body Analyzer Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the battery door
    • Open the compartment
    • Gently remove the batteries from their designated positions
    • Place them aside, away from the reach of children
  2. Withings Smart Body Analyzer Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Withings Smart Body Analyzer Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Withings Smart Body Analyzer Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With caution, insert the plastic opening tools in between the disk and the glass face
    • It's a tight fit, so don't be afraid to apply a little bit of force
    • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
    • Gently rotate the plastic spudger around the disk to get around the adhesive
    • Gently lift the metal disk
    • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
    • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
  3. Withings Smart Body Analyzer Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Withings Smart Body Analyzer Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After all the above steps have been completed, proceed by removing the glass face
    • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
    • Run the plastic spudger all around the scale to increase the gap size
    • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
    • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
    • Repeat the above steps four times
    • After all the adhesives has been removed, gently lift the glass face off
  4. Withings Smart Body Analyzer Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Withings Smart Body Analyzer Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips-head screwdriver, unscrew the two screws that are securing the motherboard in place
  5. Withings Smart Body Analyzer Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic spudger, disconnect the LCD display's ribbon cable from the motherboard.
  6. Withings Smart Body Analyzer Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the two screws and the ribbon cable are detached, remove the motherboard.
Ashley Dauphinee
crwdns2935283:003/22/17crwdne2935283:0
323 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S4-G1, Julie Spring 2017 crwdns2935289:0UMass Dartmouth, Team S4-G1, Julie Spring 2017crwdne2935289:0
UMASSD-JULIE-S17S4G1
My Wifi Body scale cannot connect to Wifi or my app. Everything else works. Where can I have it repaired. Please advise.
Mel - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
where do you get the motherboard?
cost?
donald taylor - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 114
crwdns2942667:0crwdne2942667:0 7,994
