Withings Smart Body Analyzer LCD Screen Replacement
  1. Withings Smart Body Analyzer LCD Screen Replacement, Withings Smart Body Analyzer Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the battery door
    • Open the compartment
    • Gently remove the batteries from their designated positions
    • Place them aside, away from the reach of children
  2. Withings Smart Body Analyzer LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Withings Smart Body Analyzer LCD Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Withings Smart Body Analyzer LCD Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With caution, insert the plastic opening tools in between the disk and the glass face
    • It's a tight fit, so don't be afraid to apply a little bit of force
    • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
    • Gently rotate the plastic spudger around the disk to get around the adhesive
    • Gently lift the metal disk
    • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
    • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
    The wire may be soldered to the metal plate and require desoldering/cutting to remove.
    Jason Kupka - crwdns2934203:0crwdne2934203:0
  3. Withings Smart Body Analyzer LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Withings Smart Body Analyzer LCD Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After all the above steps have been completed, proceed by removing the glass face
    • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
    • Run the plastic spudger all around the scale to increase the gap size
    • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
    • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
    • Repeat the above steps four times
    • After all the adhesives has been removed, gently lift the glass face off
  4. Withings Smart Body Analyzer LCD Screen Replacement, LCD Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Withings Smart Body Analyzer LCD Screen Replacement, LCD Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After the tempered glass panel has been removed, the screen can be accessed and is connected by a ribbon cable via the circuit board.
    • Gently remove the wire from the circuit board by gently pushing downward and away from the screen, on the metal tab that connects the wire to the circuit board.
  5. Withings Smart Body Analyzer LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips screwdriver head, unscrew the two screws that hold the screen in place.
  6. Withings Smart Body Analyzer LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The screen should be free from all constraints and all that is left is to carefully lift and remove the screen.
    Do you have a way test the led panel?
    Replacement cost?
    john allen - crwdns2934203:0crwdne2934203:0
omar shehadi
crwdns2935283:003/22/17crwdne2935283:0
207 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S4-G1, Julie Spring 2017 crwdns2935289:0UMass Dartmouth, Team S4-G1, Julie Spring 2017crwdne2935289:0
UMASSD-JULIE-S17S4G1
Where can I get a new LCD screen for replacement?
Putra Jaya - crwdns2934203:0crwdne2934203:0
problem is that I didn´t find new LCD on the internet :-(
krwell - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,407
