crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Withings Body Cardiocrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Withings Body Cardio Teardown, Opening the scale: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Withings Body Cardio Teardown, Opening the scale: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Withings Body Cardio Teardown, Opening the scale: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Opening up the scale was not an easy task – there was a lot of double-sided tape involved.
    • The back of the scale is fastened with four Torx screws – easy enough. The entire backplate, however, is glued to the front with double-sided adhesive cushions. Removing it simply involved pulling it firmly enough to break the adhesive, but not so hard as to break the connectors. A hairdryer can help loosen the adhesive under the 4 corners.
    • With the backplate removed, you can immediately spot 4 loads cells, one in each corner.
  2. Withings Body Cardio Teardown, Main PCB: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Withings Body Cardio Teardown, Main PCB: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Withings Body Cardio Teardown, Main PCB: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • ARM MCU - MK22FN1M0VLL12 (NXP)
    • weighing scale and body composition front-end IC - AFE4300 (Texas Instruments)
    • battery charging IC (including battery protection) - BQ24095 (Texas Instruments)
    • WiFi and Bluetooth radio - BCM43438 (Broadcom)
    • flash memory - MX25L3233F (Macronix)
    • op-amp - AD8544
    • connector to the USB port PCB
  3. Withings Body Cardio Teardown, Block diagram: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • I’ve made an attempt to design a block diagram for the whole setup. This won’t be 100% accurate as I don’t know all the details but it will give you an idea on how the components are interlinked and work together.
November Five
crwdns2935283:008/25/16crwdne2935283:0
465 crwdns2915208:0crwdne2915208:0
crwdns2947412:041crwdne2947412:0
Thanks for sharing your experience, wouldn’t guess the double sided tape trick without your help.
Soon my scale will be deactivated by Nokia and was wondering what I can do with it.
ALMO - crwdns2934203:0crwdne2934203:0
Hi please tell me what are battery dimensions. I need to order one - cause mine is already dead.
Michal - crwdns2934203:0crwdne2934203:0
Hi, I never took note of the dimensions, it’s best you open up the scale yourself to check it out.
Since the battery is dead you’ll have to do it anyways ;)
November Five -
Thanks for the breakdown info. I'm replacing the battery as well. It's 63x50x5mm. 2100 mAh, 7.98Wh, 3.8V
I think this battery should be exactly the same:
Samsung 2100 mAh Replacement Battery for Samsung Galaxy Avant SM-G386T https://www.amazon.com/dp/B00OY9BY6W/ref...
Ryan Wills - crwdns2934203:0crwdne2934203:0
Hi,
my battery died as well. Was the Samsung battery the correct replacement?
With best regards
MArtin
spamfilter -
crwdns2936753:07crwdne2936753:0 60
crwdns2936753:030crwdne2936753:0 295
crwdns2942667:0crwdne2942667:0 28,451
