Wireless card replacement
crwdns2931587:0crwdne2931587:0
  1. Wireless card replacement, Remove the battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wireless card replacement, Remove the battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wireless card replacement, Remove the battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the laptop upside down and gently lay it down on a flat surface.
    • Slide the battery release latch to the right and the battery will pop up slightly.
    • While keeping the latch slid with one hand, grab the battery with the other hand and remove it by pivoting it upward.
    • At this point some users would turn the laptop upside down once again and press the power button a couple of times. They say that this should help dissipating all of the remaining electricity around the device. Up to you :)
  2. Wireless card replacement, Remove the captive screw of the service door: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Phillips PM2.0×4.0 screw using a PH#00 screwdriver.
  3. Wireless card replacement, Remove the service door: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wireless card replacement, Remove the service door: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wireless card replacement, Remove the service door: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With an opening tool pry off the tabs that secure the service door to the base enclosure. Start with the long edge.
    • Continue along the short edges.
    • Once you have pried the service door off as it is in pic#3, it will come out of the rear edge very easily.
  4. Wireless card replacement, Identify the components: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • RAM memory modules
    • HDD (Hard Disk Drive)
    • mSATA SSD slot
    • Wifi & BT module (Wireless card)
  5. Wireless card replacement, Disconnect the antenna cables & unfasten the screw: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wireless card replacement, Disconnect the antenna cables & unfasten the screw: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wireless card replacement, Disconnect the antenna cables & unfasten the screw: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  6. Wireless card replacement, Substitute the wireless card: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wireless card replacement, Substitute the wireless card: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wireless card replacement, Substitute the wireless card: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the standard wireless card as it is shown in the first picture and gently pull it away at the tilt angle.
    • Place the M2.0×2.5 screw in the hole of the new wifi module, tilt it, and gently insert it in its slot. Then press the wireless card down with a hand and fasten the screw using a PH #00 with the other one.
    • Using the tweezers center and hold the connectors of the antenna cables over their terminals and then press them straight down gently using your finger. Cable 1 goes with the Main terminal and Cable 2 with the Aux terminal.
Well, that’s it! Take a short break if you like and then start to reassemble your laptop from the step #3 in reverse order. Once you turn the laptop on, install the new drivers and it's done ;) Cheers
Roberto Bartolacci
crwdns2935283:002/10/18crwdne2935283:0
1.518 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 2,127
