To complete this guide, you will need to take apart the tablet almost completely.
Locate the four corners of the backplate.
Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
Un-stick the battery from the motherboard assembly with the plastic opening tool.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Desolder the battery wires from the motherboard.
Fully remove the battery from the device.
Locate each of the motherboard's 4 mm screws.
Remove each of the four 4 mm screws from the motherboard pictured to the left.
Use a Phillips #00 precision screwdriver.
Use the spudger to pry the instrument array from its plastic housing.
Slowly slide the spudger underneath the adhesive tape to un-sitck it.
Be careful not to harm the array of wires leading to this tape.
De-tatch the motherboard output wires from the screen using the tweezers.
Locate the front screen's screws.
There are two additional 4 mm screws holding the front screen.
Use the Phillips #00 screwdriver to remove the screws (pictured to the left).
Fully remove the front screen from its plastic cover.
Hi, have a Filemate tablet and the front is broke . So is the Front and Digitizer the same thing? Thank you Brenda L Glidewell
