Wintec Filemate Clear 7" Front Screen Replacement
  1. Wintec Filemate Clear 7" Front Screen Replacement, Remove the Backplate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the four corners of the backplate.
  2. Wintec Filemate Clear 7" Front Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wintec Filemate Clear 7" Front Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
  3. Wintec Filemate Clear 7" Front Screen Replacement, Remove the Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Un-stick the battery from the motherboard assembly with the plastic opening tool.
  4. Wintec Filemate Clear 7" Front Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the battery wires from the motherboard.
    • The tweezers pictured point to the two solder joints.
  5. Wintec Filemate Clear 7" Front Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fully remove the battery from the device.
  6. Wintec Filemate Clear 7" Front Screen Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate each of the motherboard's 4 mm screws.
  7. Wintec Filemate Clear 7" Front Screen Replacement, Unscrewing Everything: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wintec Filemate Clear 7" Front Screen Replacement, Unscrewing Everything: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wintec Filemate Clear 7" Front Screen Replacement, Unscrewing Everything: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove each of the four 4 mm screws from the motherboard pictured to the left.
    • Use a Phillips #00 precision screwdriver.
  8. Wintec Filemate Clear 7" Front Screen Replacement, Detach the Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wintec Filemate Clear 7" Front Screen Replacement, Detach the Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to pry the instrument array from its plastic housing.
  9. Wintec Filemate Clear 7" Front Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly slide the spudger underneath the adhesive tape to un-sitck it.
    • Be careful not to harm the array of wires leading to this tape.
  10. Wintec Filemate Clear 7" Front Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • De-tatch the motherboard output wires from the screen using the tweezers.
  11. Wintec Filemate Clear 7" Front Screen Replacement, Front Screen: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the front screen's screws.
  12. Wintec Filemate Clear 7" Front Screen Replacement, Remove the Extra Screws: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wintec Filemate Clear 7" Front Screen Replacement, Remove the Extra Screws: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are two additional 4 mm screws holding the front screen.
    • Use the Phillips #00 screwdriver to remove the screws (pictured to the left).
  13. Wintec Filemate Clear 7" Front Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fully remove the front screen from its plastic cover.
Nicholas Ferraro
crwdns2935283:001/20/15crwdne2935283:0
431 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 19-6, Blackwell Spring 2014 crwdns2935289:0USF Tampa, Team 19-6, Blackwell Spring 2014crwdne2935289:0
USFT-BLACKWELL-S14S19G6
crwdns2935297:011crwdne2935297:0
Hi, have a Filemate tablet and the front is broke . So is the Front and Digitizer the same thing? Thank you Brenda L Glidewell
Brenda L Glidewell - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 173
