Window Operator Link Replacement
  1. Window Operator Link Replacement, Link: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Window Operator Link Replacement, Link: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Flathead 4 mm Screwdriver
    $5.49
    • Remove the four (4) window clips that holds the screen.
    • Your amount of window clips may vary depending on the size of your window.
    • Use the Flathead 4 mm Screwdriver to loosen the clip. The clip doesn't need to be removed.
    • Remove the screen and put it aside.
  2. Window Operator Link Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Window Operator Link Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Window Operator Link Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Large Needle Nose Pliers
  3. Window Operator Link Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Window Operator Link Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Window Operator Link Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #2 Screwdriver , remove the two bolts that are holding the operator into the window frame.
    • Behind the window, you will have one self retaining nut per bolt.
    • In some cases, you will need to play with the operator in order to take it out due to the small tolerances in the window.
  4. Window Operator Link Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Window Operator Link Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Window Operator Link Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Metal Spudger
    $2.99
  5. Window Operator Link Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Window Operator Link Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Window Operator Link Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the warped or broken link is removed, follow the Step 4 in reverse order.
    • You may use the Large Needle Nose Pliers to force the e-clip into place.
To reassemble your device, follow from step three (3) to one (1) in reverse order.
Alondra M. Soto Vega
crwdns2935283:010/06/21crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
University of Puerto Rico Mayagüez, Team 1-8, Cools Stephens Fall 2021 crwdns2935289:0University of Puerto Rico Mayagüez, Team 1-8, Cools Stephens Fall 2021crwdne2935289:0
UPRM-COOLS STEPHENS-F21S1G8
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 1,216
