Remove the two screws on one side of the armchair, at the ends of the armrest using the T25 screwdriver
The upper screw is a short one
The lower screw is a long one
With a decent amount of force, pull the armrest parallel to the screws.
Remove the two screws from the other side of the chair (on the other, remaining armrest)
Remove the armrest similarly to the other side, along the screw axis
Mind the two circular plastic washers on the lower axes
Mind the two plastic inner washers (that are parallel to the axes
Finally, the shaft may be removed from the other armrest as well, however, it can be stuck sometimes (you could possibly use a plier, but it can damage the shaft's surface)
Love this guide, its fantastic! Not many places on the internet that reference repair or disassembly of the Wilkhahn FS line chairs. You sir are a brilliant person.
Side note, does anyone know how to replace/dissemble the gas strut/lift for this Wilkhahn FS line chair?
william - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
my FS 211/8 is from the mid-1980s, newer models have different levers to adjust the resistance of the syncro mechanism.
0 get a replacement gas strut
1 pull the seat to the highest position and turn chair upside down
2 remove the plastic covers at the bottom of the column and around the levers under the seat with a screwdriver.
3 at floor end of column: slide retaining clip off the plunger with a flat blade screw driver. plunger will drop into column.
4 lift / remove entire wheel assembly with the column. do not lose bearing, washers and rubber end stop inside column.
5 remove hex nut connecting the up/down lever to the gas strut (under seat).
6 remove gas strut from seat. it is only pushed into the seat and held by friction. it's a TIGHT fit. use water pump pliers, grip firm. losen strut from seat with small cw/ccw movements. eventually it will come off.
7 put replacement gas strut into place. pushi it into seat FIRMLY. reassemble in reverse order.
Does anybody know how to replace the cushion / fabric? Have 2 of these and they are still great, only the fabric is getting a little too dirty.
C G - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Wilkhahn makes replacement upholstered shells for the FS chair. Get in contact with your nearest Wilkhahn dealer. By performing the above you can then clip the shell off and clip on the new shell.
Brett - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
