This guide will help you to replace the speakers if you are experiencing audio issues.
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
With your finger, press down and pull back on the battery connector plug.
Remove the battery from the battery case.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
Unplug outer case rumble motor connector from the motherboard with your fingers.
With your fingers, unplug the left speaker cable from the motherboard.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the right speaker cable that's connected to the motherboard with the tweezers.
Awesome guide, replacement speakers worked flawlessly!!
