Wii U GamePad Outer Case Replacement
  1. Wii U GamePad Outer Case Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Wii U GamePad Outer Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the battery plate.
  3. Wii U GamePad Outer Case Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wii U GamePad Outer Case Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wii U GamePad Outer Case Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
  4. Wii U GamePad Outer Case Replacement, Outer Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wii U GamePad Outer Case Replacement, Outer Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wii U GamePad Outer Case Replacement, Outer Case: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
  5. Wii U GamePad Outer Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
    • Do not pull on the wires as shown in this picture, they will likely break off. Pull directly on the plug (NOT the receptacle)
crwdns2935229:05crwdne2935229:0
Valentina Cerruty
crwdns2935283:002/10/16crwdne2935283:0
3.500 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-6, Sullivan Spring 2016 crwdns2935289:0USF Tampa, Team 1-6, Sullivan Spring 2016crwdne2935289:0
USFT-SULLIVAN-S16S1G6
crwdns2935297:040crwdne2935297:0
This doesn't show anything about taking the front of the housing off, is that relatively straightforward?
Will Prosser - crwdns2934203:0crwdne2934203:0
This doesn't show anything about the L and R sticks like moving on its own when i play, do you how to fix that?
Victoria Gonzalez - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 7,140
