Wii U GamePad Outer Case Replacement
  1. Wii U GamePad Outer Case Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
    tried to unscrew the 10 Tri-Wing size Y1 screw with my iFixIt toolkit
    unfortunately the tool is too “fat” and short, it cannot reach 4 screws on the corners of the gamepad.
    having the iFixIt toolkit and needing to purchase an additional slim screwdriver it’s a shame…
    AJtriple - crwdns2934203:0crwdne2934203:0
  2. Wii U GamePad Outer Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the battery plate.
  3. Wii U GamePad Outer Case Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wii U GamePad Outer Case Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wii U GamePad Outer Case Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
    Battery lifts up from the bottom not the top like the photo shows.
    Tyler Schommer - crwdns2934203:0crwdne2934203:0
  4. Wii U GamePad Outer Case Replacement, Outer Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wii U GamePad Outer Case Replacement, Outer Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wii U GamePad Outer Case Replacement, Outer Case: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
    I used a small blade tip to life up on the black squares that covered the screw holes. Replacing them after.. I skipped that as it seemed impossible they would even stick back down.
    Chris - crwdns2934203:0crwdne2934203:0
    I am having trouble getting the two screws on the hand grips as the screws are too deep. What should I use to get them?
    [deleted] - crwdns2934203:0crwdne2934203:0
    I ended up having to buy some cheap amazon screwdrivers and are very disappointed
    [deleted] -
  5. Wii U GamePad Outer Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
    • Do not pull on the wires as shown in this picture, they will likely break off. Pull directly on the plug (NOT the receptacle)
    Do not pull by the wires! If you do, you better be pretty good at soldering.
    Brandon - crwdns2934203:0crwdne2934203:0
    I agree. A circle over the plug would have been better as the picture looks like you just pull on the wires lol.
    Chris -
    Thanks for the comment. I did get a set of tweezers and the negative cable broke anyway. They really could have done a better job at using a different connector for that.
    Kristen Bartholomew -
    Great. Didn't pull on cord. Whole thing ripped off.
    August - crwdns2934203:0crwdne2934203:0
    Why in the world is this thing so tightly connected?
    Andrew Moore - crwdns2934203:0crwdne2934203:0
    Thanks for the comment. I did get a set of tweezers to try to pull it out but still ended up breaking the negative cable. They really could have used a better set of cables and connectors for this.
    Kristen Bartholomew - crwdns2934203:0crwdne2934203:0
    You don’t have to do this step!!!! Just open the switch while keeping this wire intact!!!!!
    Garrison Bradford - crwdns2934203:0crwdne2934203:0
crwdns2935229:05crwdne2935229:0
Valentina Cerruty
crwdns2935283:002/10/16crwdne2935283:0
3.500 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-6, Sullivan Spring 2016 crwdns2935289:0USF Tampa, Team 1-6, Sullivan Spring 2016crwdne2935289:0
USFT-SULLIVAN-S16S1G6
crwdns2935297:040crwdne2935297:0
This doesn't show anything about taking the front of the housing off, is that relatively straightforward?
Will Prosser - crwdns2934203:0crwdne2934203:0
This doesn't show anything about the L and R sticks like moving on its own when i play, do you how to fix that?
Victoria Gonzalez - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 7,155
