Wii U GamePad Camera Replacement
  1. Wii U GamePad Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Wii U GamePad Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the battery plate.
  3. Wii U GamePad Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wii U GamePad Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wii U GamePad Camera Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
  4. Wii U GamePad Camera Replacement, Outer Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wii U GamePad Camera Replacement, Outer Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wii U GamePad Camera Replacement, Outer Case: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
  5. Wii U GamePad Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
    • Do not pull on the wires as shown in this picture, they will likely break off. Pull directly on the plug (NOT the receptacle)
  6. Wii U GamePad Camera Replacement, Speakers: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wii U GamePad Camera Replacement, Speakers: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With your fingers, unplug the left speaker cable from the motherboard.
  7. Wii U GamePad Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wii U GamePad Camera Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the right speaker cable that's connected to the motherboard with the tweezers.
  8. Wii U GamePad Camera Replacement, Wi-Fi Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wii U GamePad Camera Replacement, Wi-Fi Board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wii U GamePad Camera Replacement, Wi-Fi Board: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer.
    • Remove the white flex cable with the tweezers.
  9. Wii U GamePad Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wii U GamePad Camera Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With your fingers, lift and remove Wi-Fi board.
    • Remove the board carefully as there are still two wires attached.
  10. Wii U GamePad Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wii U GamePad Camera Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the black and white wires off of the back of the Wi-Fi module.
  11. Wii U GamePad Camera Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the Wi-Fi module.
  12. Wii U GamePad Camera Replacement, Motherboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the analog connector with tweezers.
  13. Wii U GamePad Camera Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wii U GamePad Camera Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the blue connector using tweezers.
  14. Wii U GamePad Camera Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wii U GamePad Camera Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the black clasp. It is prone to breaking if only lifted from one point. Remove the brown ribbon by using the tweezers.
    • Unclasp and release the small digitizer ribbon cable to the left of the brown ribbon.
    • Be careful, the small clasp breaks easily.
  15. Wii U GamePad Camera Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the small orange ribbon with the tweezers.
  16. Wii U GamePad Camera Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wii U GamePad Camera Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wii U GamePad Camera Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove these two connectors to the motherboard with your fingers.
  17. Wii U GamePad Camera Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wii U GamePad Camera Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the NFC communicator.
    • When removing the NFC communicator, be careful with the small connector on the back side.
    • Remove the small connector plug-in on the back.
  18. Wii U GamePad Camera Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wii U GamePad Camera Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wii U GamePad Camera Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the remaining three 5.1 mm screws using the Phillips size #0 screwdriver.
    • Lift and remove the mother board.
  19. Wii U GamePad Camera Replacement, Camera: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wii U GamePad Camera Replacement, Camera: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip motherboard over.
    • Remove the metal housing around the camera with tweezers.
  20. Wii U GamePad Camera Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the camera out using the tweezers.
Valentina Cerruty
crwdns2935283:002/10/16crwdne2935283:0
3,500 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-6, Sullivan Spring 2016 crwdns2935289:0USF Tampa, Team 1-6, Sullivan Spring 2016crwdne2935289:0
USFT-SULLIVAN-S16S1G6
crwdns2935297:040crwdne2935297:0
crwdns2942667:0crwdne2942667:0 2,522
