Wii Balance Board Battery Case Replacement
  1. Wii Balance Board Battery Case Replacement, Unscrewing the Foot Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Battery Case Replacement, Removing the Foot Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Battery Case Replacement, Removing the Foot: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Battery Case Replacement, Removing the Additional Feet: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat steps two and three on the remaining four feet.
  5. Wii Balance Board Battery Case Replacement, Unscrewing the Back Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Battery Case Replacement, Removing the Back Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift off the gray back cover.
  7. Wii Balance Board Battery Case Replacement, Battery Compartment: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wii Balance Board Battery Case Replacement, Battery Compartment: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Wii Balance Board Battery Case Replacement, Removing the Battery Case: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
crwdns2935229:019crwdne2935229:0
Michelle Reed
crwdns2935283:009/29/14crwdne2935283:0
515 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-8, Forte Fall 2014 crwdns2935289:0Cal Poly, Team 13-8, Forte Fall 2014crwdne2935289:0
CPSU-FORTE-F14S13G8
crwdns2947412:014crwdne2947412:0
I unscrewed everything, but were do i find a replacement battery compartent?
Olivia C - crwdns2934203:0crwdne2934203:0
Then what do you do after you remove the battery case?
CRAIG WIKMAN - crwdns2934203:0crwdne2934203:0
Is there a way to open the top of the board by sliding or lifting the top? I bought a gently used wii fit. The lady who sold it to me very quickly opened the top of the board from the centre seam to show me the instruction manual and I think hook up cables. I cannot, for the life of me figure out how she did it! Any ideas or technical wizardry you can share?
Frustrated in Canada!
Pam Murray - crwdns2934203:0crwdne2934203:0
Why tell to remove all those parts and then there's no replacement battery board
Valerie Triplin - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 49
crwdns2936753:030crwdne2936753:0 226
crwdns2942667:0crwdne2942667:0 45,541
