Wihoo SF01 Portable Electric Fan Tripod Leg Replacement
  1. Wihoo SF01 Portable Electric Fan Tripod Leg Replacement, Tripod Leg: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To avoid accidentally turning on the fan, make sure to take all batteries out of the device before starting this process.
  2. Wihoo SF01 Portable Electric Fan Tripod Leg Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the fan on a stable table and unscrew the back frame with a screw driver.
    • If the screws are very tight, apply steady downward pressure and gently wiggle the screwdriver as you turn to avoid stripping them.
  3. Wihoo SF01 Portable Electric Fan Tripod Leg Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wihoo SF01 Portable Electric Fan Tripod Leg Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wihoo SF01 Portable Electric Fan Tripod Leg Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the fan over and detach the front frame so that the tripod base is able to be removed.
    • Frames can be detached by unclipping the sides with a little force.
    • If needed, a spudger can help to detach the tabs.
  4. Wihoo SF01 Portable Electric Fan Tripod Leg Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the top portion of the base and unscrew all three screws.
  5. Wihoo SF01 Portable Electric Fan Tripod Leg Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic cover that is on the bottom of the base holding the tripod legs in place.
    • The cover does not have to be completely removed, just enough to fit the base of the tripod leg into its spot.
  6. Wihoo SF01 Portable Electric Fan Tripod Leg Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the replacement tripod leg into its respective spot.
    • You may hear a small click which means it has been snapped into place.
  7. Wihoo SF01 Portable Electric Fan Tripod Leg Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the plastic covering so that all the legs can stay in place again.
    • This may involve bending the legs around to get a better angle.
    • Make sure to move your fingers out of the way so they are not pinched in between the cover and base when closing it.
  8. Wihoo SF01 Portable Electric Fan Tripod Leg Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the screws into the top of the base and screw them completely back.
  9. Wihoo SF01 Portable Electric Fan Tripod Leg Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fit the tripod legs/base back onto the frame.
  10. Wihoo SF01 Portable Electric Fan Tripod Leg Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Snap the front frame on top of the back frame.
    • Make sure all sides are secure.
    • You should hear a click into place for each tab.
  11. Wihoo SF01 Portable Electric Fan Tripod Leg Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wihoo SF01 Portable Electric Fan Tripod Leg Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Finally replace both screws on the back frame and use a screwdriver to properly screw them in so that the frame stays firmly in place.
    • Left for loose | Right for tight
Lauren Calderon
crwdns2935283:005/12/25crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
UC Davis, Team 1-3, Whithaus Spring 2025 crwdns2935289:0UC Davis, Team 1-3, Whithaus Spring 2025crwdne2935289:0
UCD-WHITHAUS-S25S1G3
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 158
