Sollte ein Brustgurt aus seiner Führungsschiene brechen oder verloren gegangen sein, kannst du diesen einfach wieder ersetzen.
Brustgurt am Ende der Führungsschiene (schmale Stelle) ansetzen.
Brustgurt am Ende der Führungsschiene (schmale Stelle) wieder einführen.
Das sieht so leicht aus….ich schaffe das nicht….
meyerbestwig@gmail.com
Where could I find a replacement rail buckle? I need one to install as you suggest!
Have you ever found out where to buy it?
zinelg -
check this out: https://www.vaude.com/de-DE/Ausruestung/...
crwdns2917034:0crwdne2917034:0
Also works on the Vaude Petros bag (115630100). It does not have the thin end on the rail, but you can easily make one of the ends thin by gently squeezing it with a pair of pliers.
Fine Way to do it If you have a thin end of the trail at your Vaude backpack. I do not have that.
Any tips on how to get the strap onto the trail without “a thin end og the trail”?
Leif Svendsen - crwdns2934203:0crwdne2934203:0
Yep. Same here. Any advice?
K c -
Where can I find a rail sternum strap to replace the missing one?
CMcCraw - crwdns2934203:0crwdne2934203:0
