Why! WDi7SSD SSD Hard Drive Replacement
  1. Why! WDi7SSD SSD Hard Drive Replacement, why! WDi7SSD Opening procedure: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Why! WDi7SSD SSD Hard Drive Replacement, why! WDi7SSD Opening procedure: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Why! WDi7SSD SSD Hard Drive Replacement, why! WDi7SSD Opening procedure: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the computer is disconnected from the power source.
    • Flip the computer over.
    • Remove the six screws with a 2 mm Allen key.
    • Carefully remove the back panel, as well the left and right panel.
  2. Why! WDi7SSD SSD Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now flip up the base panel to which all components are attached.
  3. Why! WDi7SSD SSD Hard Drive Replacement, SSD Hard Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Why! WDi7SSD SSD Hard Drive Replacement, SSD Hard Drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Why! WDi7SSD SSD Hard Drive Replacement, SSD Hard Drive: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove the four screws on the heatsink that cools the processor unit.
    • Remove the heatsink.
  4. Why! WDi7SSD SSD Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Why! WDi7SSD SSD Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Why! WDi7SSD SSD Hard Drive Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The SSD is now visible.
    • Now flip the computer over and use the Allen wrench to loosen the 1.5 mm screws fixing the SSD.
  5. Why! WDi7SSD SSD Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Why! WDi7SSD SSD Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the first cable from the SSD. You must press the lever down to do this.
    • The cable may not loosen easily. In this case, carefully use a little force, but not too much.
    • Pay attention do the orientation when assembling. Otherwise, the SSD and cable can be damaged.
  6. Why! WDi7SSD SSD Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Why! WDi7SSD SSD Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the second cable from the SSD. You must press the lever down to do this.
To reassemble the device, follow the instructions in reverse order.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Felice Suglia
crwdns2935283:006/15/13crwdne2935283:0
33,538 crwdns2915208:0crwdne2915208:0
crwdns2935297:0283crwdne2935297:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 206
