Whirlpool WED87HED Dryer Idler Pulley Replacement
  1. Whirlpool WED87HED Dryer Idler Pulley Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool WED87HED Dryer Idler Pulley Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    FixMat
    $36.95
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a 5/16 inch nut driver to remove the two 15.7 mm-long screws securing the top panel to the rear panel bracket.
  3. Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool WED87HED Dryer Idler Pulley Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool WED87HED Dryer Idler Pulley Replacement, Unfasten the cover plate: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 5/16 inch nut driver to remove the 16.2 mm-long cover plate screw.
  6. Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the cover plate: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the cover plate: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the cover plate: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cover plate.
  7. Whirlpool WED87HED Dryer Idler Pulley Replacement, Disconnect the cord: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Mark the cables with a permanent marker if needed and take a picture or draw a diagram.
    • Use a Phillips driver or a 1/4 inch nut driver to remove the three 21.4 mm-long screws.
    • If your plug has 4 prongs, there will be a ground connection from the cord as well. Use a 5/16 inch nut driver to remove this connection.
  8. Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the cord: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the cord: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the cord: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the cord carefully down through the round hole.
    • Make sure you replace the connections correctly when you reassemble.
  9. Whirlpool WED87HED Dryer Idler Pulley Replacement, Unfasten the cord terminal block: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 5/16 inch hex driver to remove the 16.5 mm-long green ground screw.
    • Use a Phillips driver to remove the two 15.3 mm‑long cord terminal block screws.
  10. Whirlpool WED87HED Dryer Idler Pulley Replacement, Move the cord terminal block: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Move the cord terminal block: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Move the cord terminal block: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the cord terminal block behind the rear panel.
  11. Whirlpool WED87HED Dryer Idler Pulley Replacement, Unfasten the rear panel: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Unfasten the rear panel: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $36.95
    • Use a 1/4 inch nut driver to remove the eleven rear panel screws.
    • Ten 20 mm-long screws
    • One 12.9 mm-long screw under the water inlet.
  12. Whirlpool WED87HED Dryer Idler Pulley Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 1/4 inch nut driver to remove the 16.4 mm-length screw holding the main board bracket to the chassis.
    • Use a 1/4 inch nut driver to remove the two 20 mm-long screws from the top rear of the machine.
  13. Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the rear panel: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the rear panel: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the rear panel: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put on gloves before continuing, as the rear panel is sharp.
    • Lift the panel about 1/2 inch and tilt it to the rear to release it from the vent pipe.
    • Slide the panel off the vent pipe and remove it.
  14. Whirlpool WED87HED Dryer Idler Pulley Replacement, Reassembly information: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Reassembly information: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • During reassembly, perform the following:
    • Make sure that the vent pipe is fitted into the collar on the panel.
    • Make sure the tabs at the bottom are aligned to the bottom rim of the chassis.
    • Position the panel so its screw holes match with the chassis.
  15. Whirlpool WED87HED Dryer Idler Pulley Replacement, Unfasten the idler arm: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 3/8 inch socket, or a nut driver, to remove the bolt securing the idler arm to the motor frame.
  16. Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the idler arm: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the idler arm: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the idler arm: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the idler arm toward the side of the dryer to unhook the idler arm tension spring from the arm.
    • Remove the idler arm.
    • During reassembly, be sure to reattach the spring before securing the arm.
  17. Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the retaining clip: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the retaining clip: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the retaining clip: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use long nose pliers to remove the plastic retaining clip from the groove in the idler pulley shaft.
  18. Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the idler pulley: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the idler pulley: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool WED87HED Dryer Idler Pulley Replacement, Remove the idler pulley: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the idler pulley straight off its shaft and remove it.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
37.849 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.981crwdne2935297:0
crwdns2942667:0crwdne2942667:0 386
