Use this guide to replace your Whirlpool Side by Side Refrigerator W10325109A light. The model of the LED light is w10515058. This tends to happen all the time as LEDs have a life expectancy. This guide is very easy and only requires an opening tool like the iFixit opening tool that will allow you to remove the light.
Before ordering a new LED I recommend taking it out and inspecting, this way you can see if its an issue with the refrigerator or the light. Before starting this guide be sure to unplug the refrigerator to turn off power.
Make sure electricity is off, do this by unplugging your refrigerator.
Detach the front two tabs of the light, using an opening tool on the perimeter of the light where it attaches to the ceiling of the refrigerator.
Do this on the back tabs of the light as well.
Disconnect the wire connectors to fully remove light.
Gentling unplug both wires, does not matter which one you do first.
Install the new LED light by putting back the wire connectors.
Reattach the corresponding connectors to the LED.
Put the LED light back into place.
Push the LED light into the position it was before, use needed force.
