IMPORTANT SAFETY NOTICE
Before working on appliances, find someone knowledgeable and always unplug the appliance yourself! It's a life-or-death situation.
WHIRLPOOL THIN TWIN WASHING MACHINE ISSUSE
Problem: Won't drain during wash cycle?
I'm not a professional; just sharing my experience.
STEPS TO RESOLVE
1. Check shut-off lid switch.
2. Inspect hoses (inside 2 and outside 1 hose) for kinks or clogs.
3. Verify drain pump cleanliness and functionality.
DRAIN PUMP ACCESS
1. ALWAYS UNPLUG THE WASHER YOURSELF!
2. Turn off and disconnect water lines (secure them).
3. Remove front cover (2 screws).
4. Take off 2 metal clips holding plastic drain pump.
5. Remove wire clamps (2 hoses, 1 wire squeeze clamp each).
6. Carefully slide off pump.
TROUBLESHOOTING
1. Clean or unclog pump and hoses.
2. Reassemble, ensuring secure connections.
3. Test after reassembly.
SAFETY PRECAUTIONS
1. Dry all water before replugging.
2. Avoid poor reassembly.
REPLACEMENT PARTS
1. Drain pump (~ $15 on Amazon or find name brand).
2. Match pump number when ordering.
LIMITATIONS
If issues persist, consider professional help, especially for motor replacement.
FINAL THOUGHTS
Best wishes! God bless you and your family!
Note: Minor adjustments for clarity and readability.
