Whirlpool Dryer Steam Nozzle Replacement
  1. Whirlpool Dryer Steam Nozzle Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool Dryer Steam Nozzle Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    FixMat
    $31.41
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
  3. Whirlpool Dryer Steam Nozzle Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool Dryer Steam Nozzle Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool Dryer Steam Nozzle Replacement, Unfasten the cover plate: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cover plate screw.
  6. Whirlpool Dryer Steam Nozzle Replacement, Remove the cover plate: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Remove the cover plate: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Remove the cover plate: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cover plate.
  7. Whirlpool Dryer Steam Nozzle Replacement, Disconnect the cord: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws securing the cord cables.
    • Mark the cables with a permanent marker if needed and take a picture or draw a diagram.
  8. Whirlpool Dryer Steam Nozzle Replacement, Remove the cord: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Remove the cord: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Remove the cord: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the cord carefully down through the round hole.
    • Make sure you replace the connections correctly when you reassemble.
  9. Whirlpool Dryer Steam Nozzle Replacement, Unfasten the cord terminal block: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the green ground screw.
    • Remove the cord terminal block screws.
  10. Whirlpool Dryer Steam Nozzle Replacement, Move the cord terminal block: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Move the cord terminal block: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Move the cord terminal block: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the cord terminal block behind the rear panel.
  11. Whirlpool Dryer Steam Nozzle Replacement, Unfasten the rear panel: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Unfasten the rear panel: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $31.41
    • Remove the rear panel screws.
  12. Whirlpool Dryer Steam Nozzle Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw holding the main board bracket to the chassis.
    • Remove the screws from the top rear of the machine.
  13. Whirlpool Dryer Steam Nozzle Replacement, Remove the rear panel: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Remove the rear panel: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Remove the rear panel: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put on gloves before continuing, as the rear panel is sharp.
    • Lift the panel about 1/2 inch and tilt it to the rear to release it from the vent pipe.
    • Slide the panel off the vent pipe and remove it.
  14. Whirlpool Dryer Steam Nozzle Replacement, Reassembly information: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Reassembly information: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • During reassembly, perform the following:
    • Make sure that the vent pipe is fitted into the collar on the panel.
    • Make sure the tabs at the bottom are aligned to the bottom rim of the chassis.
    • Position the panel so its screw holes match with the chassis.
  15. Whirlpool Dryer Steam Nozzle Replacement, Disconnect the water tube: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Disconnect the water tube: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Disconnect the water tube: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the retaining clip out with a small screwdriver or spudger.
    • Grab the retaining clip with your fingertips and remove it.
  16. Whirlpool Dryer Steam Nozzle Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the yellow sleeve toward the valve to release the water tube.
    • While holding the sleeve in place, pull the water tube out of the sleeve
  17. Whirlpool Dryer Steam Nozzle Replacement, Unfasten the nozzle cover: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the sheet metal screw securing the steam nozzle cover.
    • Be careful not to drop any tools as you work, or you may chip the drum's enamel coating
  18. Whirlpool Dryer Steam Nozzle Replacement, Remove the nozzle cover: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Remove the nozzle cover: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Remove the nozzle cover: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the lower edge of the cover and tilt it outward to clear the nozzle.
    • Slide the cover down to disengage the tab at the upper end of the cover.
    • Remove the cover.
  19. Whirlpool Dryer Steam Nozzle Replacement, Unfasten nozzle assembly: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the nozzle assembly screw.
  20. Whirlpool Dryer Steam Nozzle Replacement, Remove nozzle assembly: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Remove nozzle assembly: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Steam Nozzle Replacement, Remove nozzle assembly: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the nozzle assembly up to disengage the tab at the lower end.
    • Remove the nozzle assembly.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
37.810 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.728crwdne2935297:0
crwdns2942667:0crwdne2942667:0 351
