Whirlpool Dryer Idler Pulley Replacement
  1. Whirlpool Dryer Idler Pulley Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool Dryer Idler Pulley Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    FixMat
    $31.41
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
  3. Whirlpool Dryer Idler Pulley Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool Dryer Idler Pulley Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool Dryer Idler Pulley Replacement, Unfasten the cover plate: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cover plate screw.
  6. Whirlpool Dryer Idler Pulley Replacement, Remove the cover plate: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Remove the cover plate: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Remove the cover plate: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cover plate.
  7. Whirlpool Dryer Idler Pulley Replacement, Disconnect the cord: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws securing the cord cables.
    • Mark the cables with a permanent marker if needed and take a picture or draw a diagram.
  8. Whirlpool Dryer Idler Pulley Replacement, Remove the cord: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Remove the cord: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Remove the cord: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the cord carefully down through the round hole.
    • Make sure you replace the connections correctly when you reassemble.
  9. Whirlpool Dryer Idler Pulley Replacement, Unfasten the cord terminal block: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the green ground screw.
    • Remove the cord terminal block screws.
  10. Whirlpool Dryer Idler Pulley Replacement, Move the cord terminal block: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Move the cord terminal block: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Move the cord terminal block: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the cord terminal block behind the rear panel.
  11. Whirlpool Dryer Idler Pulley Replacement, Unfasten the rear panel: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Unfasten the rear panel: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $31.41
    • Remove the rear panel screws.
  12. Whirlpool Dryer Idler Pulley Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw holding the main board bracket to the chassis.
    • Remove the screws from the top rear of the machine.
  13. Whirlpool Dryer Idler Pulley Replacement, Remove the rear panel: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Remove the rear panel: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Remove the rear panel: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put on gloves before continuing, as the rear panel is sharp.
    • Lift the panel about 1/2 inch and tilt it to the rear to release it from the vent pipe.
    • Slide the panel off the vent pipe and remove it.
  14. Whirlpool Dryer Idler Pulley Replacement, Reassembly information: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Reassembly information: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • During reassembly, perform the following:
    • Make sure that the vent pipe is fitted into the collar on the panel.
    • Make sure the tabs at the bottom are aligned to the bottom rim of the chassis.
    • Position the panel so its screw holes match with the chassis.
  15. Whirlpool Dryer Idler Pulley Replacement, Unfasten the idler arm: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bolt securing the idler arm to the motor frame.
  16. Whirlpool Dryer Idler Pulley Replacement, Remove the idler arm: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Remove the idler arm: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Remove the idler arm: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the idler arm toward the side of the dryer to unhook the idler arm tension spring from the arm.
    • Remove the idler arm.
    • During reassembly, be sure to reattach the spring before securing the arm.
  17. Whirlpool Dryer Idler Pulley Replacement, Remove the retaining clip: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Remove the retaining clip: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Remove the retaining clip: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use long nose pliers to remove the plastic retaining clip from the groove in the idler pulley shaft.
  18. Whirlpool Dryer Idler Pulley Replacement, Remove the idler pulley: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Remove the idler pulley: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Idler Pulley Replacement, Remove the idler pulley: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the idler pulley straight off its shaft and remove it.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
37,849 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,947crwdne2935297:0
Thank you for the very detailed instructions! I can’t get the back off of my WED6120HC0 and I don’t want to damage it by pulling it. It feels as though it’s still fastened though I don’t see anything further to remove. Any help would greatly appreciated!
Ken - crwdns2934203:0crwdne2934203:0
Hi Ken! Where does it feel like is is still fastened? There is a sleeve on the back panel that goes around the exhaust duct that could be binding a bit. Does it feel like it is fastened near the bottom? Remember that you have to lift up slightly.Look at step 13 of the guide and Step 14 as well to see how you have to reassemble it. It can feel a little stuck. Make sure you got every single fastener.
Bill Gilbert -
(Edit) The Service Manual I found does not give instructions for removing the rear panel if you are doing the idler pulley. So, I imagine it is similar to what I have shown. They do say to remove the rear panel for the water inlet valve, so it must be removable.
Bill Gilbert -
Remember the screws up under the top. The back panel bends at the top over the top edge. There are two screws, one om each corner.
Ron Ohmie - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 40
crwdns2936753:030crwdne2936753:0 135
crwdns2942667:0crwdne2942667:0 2,707
