Whirlpool Dryer Drum Roller Asembly Replacement
  1. Whirlpool Dryer Drum Roller Asembly Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    FixMat
    $36.95
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
  3. Whirlpool Dryer Drum Roller Asembly Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool Dryer Drum Roller Asembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool Dryer Drum Roller Asembly Replacement, Disconnect the control panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Disconnect the control panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the control panel cable from the main board.
  6. Whirlpool Dryer Drum Roller Asembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the drum light connector.
  7. Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the control panel: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the control panel: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws securing the control panel.
  8. Whirlpool Dryer Drum Roller Asembly Replacement, Remove the control panel: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the control panel: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the control panel: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the control panel up and tilt it away from the chassis to remove it.
    • Make sure to thread the cable through the hole in the chassis.
    • During reassembly, thread the cable through its proper hole before reinstalling the control panel.
  9. Whirlpool Dryer Drum Roller Asembly Replacement, Disconnect the door switch: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Disconnect the door switch: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Disconnect the door switch: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a small flat blade screwdriver or a spudger to unlatch both sides of the door switch connector.
    • Unplug the connector.
  10. Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the front panel: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the front panel: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the upper front panel sheet metal screws.
    • Tilt the machine backwards and prop it securely, or have a friend hold it.
    • Remove the sheet metal screws on the bottom edge of the panel.
  11. Whirlpool Dryer Drum Roller Asembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws inside the door area below the drum opening.
  12. Whirlpool Dryer Drum Roller Asembly Replacement, Remove the front panel: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the front panel: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the front panel: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The panel is heavy and awkward. You may want to have a friend help you with this step.
    • Pull the bottom of the panel away from the chassis about two to three inches.
    • Lift the front panel off the small tabs on the chassis near the top of the panel and remove it.
    • Make sure you don't snag the door switch wire harness as you remove the panel.
  13. Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the cover plate: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cover plate screw.
  14. Whirlpool Dryer Drum Roller Asembly Replacement, Remove the cover plate: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the cover plate: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the cover plate: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cover plate.
  15. Whirlpool Dryer Drum Roller Asembly Replacement, Disconnect the cord: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws securing the cord cables.
    • Mark the cables with a permanent marker if needed and take a picture or draw a diagram.
  16. Whirlpool Dryer Drum Roller Asembly Replacement, Remove the cord: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the cord: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the cord: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the cord carefully down through the round hole.
    • Make sure you replace the connections correctly when you reassemble.
  17. Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the cord terminal block: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the green ground screw.
    • Remove the cord terminal block screws.
  18. Whirlpool Dryer Drum Roller Asembly Replacement, Move the cord terminal block: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Move the cord terminal block: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Move the cord terminal block: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the cord terminal block behind the rear panel.
  19. Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the rear panel: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the rear panel: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $36.95
    • Remove the rear panel screws.
  20. Whirlpool Dryer Drum Roller Asembly Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw holding the main board bracket to the chassis.
    • Remove the screws from the top rear of the machine.
  21. Whirlpool Dryer Drum Roller Asembly Replacement, Remove the rear panel: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the rear panel: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the rear panel: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put on gloves before continuing, as the rear panel is sharp.
    • Lift the panel about 1/2 inch and tilt it to the rear to release it from the vent pipe.
    • Slide the panel off the vent pipe and remove it.
  22. Whirlpool Dryer Drum Roller Asembly Replacement, Reassembly information: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Reassembly information: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • During reassembly, perform the following:
    • Make sure that the vent pipe is fitted into the collar on the panel.
    • Make sure the tabs at the bottom are aligned to the bottom rim of the chassis.
    • Position the panel so its screw holes match with the chassis.
  23. Whirlpool Dryer Drum Roller Asembly Replacement, Remove the lint filter: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the lint filter: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the lint filter: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the lint filter up out of the lint filter slot to remove it.
    • These photos show the front panel in place, but the procedure is the same if the front panel is already removed.
  24. Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the lint filter housing: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the mounting screws securing the lint filter housing.
  25. Whirlpool Dryer Drum Roller Asembly Replacement, Remove the lint filter housing: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the lint filter housing: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the lint filter housing: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the filter housing outward from the chassis and down to remove it.
  26. Whirlpool Dryer Drum Roller Asembly Replacement, Disconnect the moisture sensor: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Disconnect the moisture sensor: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Disconnect the moisture sensor: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Squeeze the locking tabs on the moisture sensor connector.
    • Disconnect the connector.
  27. Whirlpool Dryer Drum Roller Asembly Replacement, Disconnect the main board: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Disconnect the main board: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Disconnect the main board: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Label, photograph or make a sketch of the connector locations and of the main board bracket position on your machine.
    • Disconnect all of the connectors on the main board front half.
  28. Whirlpool Dryer Drum Roller Asembly Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect all the connectors from the rear half of the main board.
  29. Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the main board from the main board bracket: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the sheet metal screw that retains the main board to the main board bracket.
  30. Whirlpool Dryer Drum Roller Asembly Replacement, Separate the main board from the main board bracket: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Separate the main board from the main board bracket: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Separate the main board from the main board bracket: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the rear corner of the main board nearest to the side walls of the chassis.
    • You want to release the locking tab on the side of the main board.
    • Slide the main board toward the front of the dryer to release the tabs securing it to the main board bracket.
  31. Whirlpool Dryer Drum Roller Asembly Replacement, Remove the main board: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the main board from the main board bracket.
  32. Whirlpool Dryer Drum Roller Asembly Replacement, Remove the main board bracket: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the sheet metal screw holding the main board bracket.
  33. Whirlpool Dryer Drum Roller Asembly Replacement, Remove the wiring harness from the main board bracket: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the wiring harness from the main board bracket: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the wiring harness from the main board bracket: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift off the main board bracket from the chassis and turn it so the bottom is exposed.
    • Using long nose or slip joint pliers, pinch the locking wings of the harness retainer clamp.
    • Separate the harness from the main board bracket and remove the main board bracket.
  34. Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the upper front bulkhead: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the upper front bulkhead: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the upper front bulkhead: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screws securing the upper front bulkhead to the front of the chassis.
    • Remove the sheet metal screws securing the top plastic portion to the upper front bulkhead.
  35. Whirlpool Dryer Drum Roller Asembly Replacement, Remove the upper front bulkhead: crwdns2935265:035crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the upper front bulkhead: crwdns2935265:035crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the upper front bulkhead: crwdns2935265:035crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the upper front bulkhead and set it aside.
  36. Whirlpool Dryer Drum Roller Asembly Replacement, Release the belt tension: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Release the belt tension: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Release the belt tension: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take careful note of the belt path before proceeding.
    • Be careful during this procedure! The idler arm is under spring tension and may pinch you, or it could damage the belt switch if the arm is allowed to snap down.
    • Push the idler arm (the metal upside-down "L") up to relieve the tension on the drive belt.
    • Remove the belt from the motor pulley.
    • Gently lower the idler arm until it rests parallel to the dryer floor.
    • During reassembly, refer to your notes or the belt path link to rethread the drive belt.
  37. Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the lower front bulkhead: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the lower front bulkhead: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws securing the lower front bulkhead.
  38. Whirlpool Dryer Drum Roller Asembly Replacement, Remove the lower front bulkhead: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the lower front bulkhead: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the lower front bulkhead: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While supporting the drum, lift the lower front bulkhead off of the hooks on the chassis.
  39. Whirlpool Dryer Drum Roller Asembly Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lower the bulkhead about 2 inches to free the drum rollers tucked under the drum.
    • While supporting the drum, remove the lower front bulkhead.
    • During reassembly, tilt the bulkhead to the right to get the rollers under the lip on the front of the drum. Once the drum is on the rollers, you can move the bulkhead to the upright position.
  40. Whirlpool Dryer Drum Roller Asembly Replacement, Remove the drum: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the drum: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the drum: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the belt to lift the drum a few inches.
    • Swing the drum out of the front of the dryer.
    • Note which end of the drum faces the front.
    • If the belt is broken, stand in front of the drum and put your arms inside it. Lift it up and pull it through the front opening of the machine. Having someone to help you with this is a good idea.
    • Make sure you get your drum back on the rollers when you reinstall the lower front bulkhead. Take your time and don't force it.
  41. Whirlpool Dryer Drum Roller Asembly Replacement, Remove the drum roller: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove the drum roller: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of long nose pliers to remove the triangular plastic retainer clip.
    • Sometimes these can pop off and fly, so make sure you have a good firm grip on the clip.
  42. Whirlpool Dryer Drum Roller Asembly Replacement, Remove drum rollers: crwdns2935265:042crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Remove drum rollers: crwdns2935265:042crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the roller unit off the roller mounting shaft.
    • Repeat the last two steps for each drum support roller on the dryer.
    • If any of the shafts are damaged (you can see and feel a groove with your fingernail or fingertip), go to the next step.
  43. Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the drum roller shaft: crwdns2935265:043crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Whirlpool Dryer Drum Roller Asembly Replacement, Unfasten the drum roller shaft: crwdns2935265:043crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a box wrench or socket wrench to loosen the nut holding the shaft to the chassis.
    • A 1/2 inch drive impact driver with an impact socket may help loosen a rusted nut.
    • If the shaft is stuck, apply some penetrating oil to help loosen it.
    • If the shaft spins when you try to loosen the mounting nut, use locking pliers to secure the shaft.
  44. Whirlpool Dryer Drum Roller Asembly Replacement, Remove the drum roller shaft: crwdns2935265:044crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the drum roller shaft.
    • Repeat the last two steps for each damaged drum support roller shaft.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
37.849 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.981crwdne2935297:0
I have a loose roller. I'm not sure if the roller inner diameter got bigger, or if the shaft ground down, or both. Perhaps it's only the roller?
leafybye - crwdns2934203:0crwdne2934203:0
You might try swapping the rollers to check. Use one of the undamaged rollers as a test. If it fits nicely on the shaft where the damaged roller was located, it's probably the inside diameter of the damaged roller that grew. You would likely see grooves or scoring on the shaft if it is worn down, so if you don't see any, it's probably the roller. Replacing the shaft takes a bit of effort because the shaft nut is really tight. You will want a breaker bar with a socket or a strong impact driver to break it free. Use a 6-point socket so you get a good grip on the faces of the nut. If the shaft is damaged, you can also grab it with locking pliers to keep it from spinning when you loosen the nut.
Bill Gilbert -
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 163
crwdns2942667:0crwdne2942667:0 2,644
