West Bend Crockery Cooker 84356 Disassembly
  1. West Bend Crockery Cooker 84356 Disassembly, West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly, West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly, West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the pot upside down. Use a pair of long nose pliers to crush the long rivet.
    • This piece was broken in our first disassembly but a new device will have a rivet that is flat against the metal.
    • Remove the long rivet once it is crushed.
  2. West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove lock washer once the long rivet is removed.
  3. West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove black metal base and set aside without disconnecting the wires.
  4. West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Follow the white wire that connects to the lamp inside the slow cooker. Find the yellow lamp.
  5. West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull on the wire at the bottom of the white sleeve. Remove the light from the yellow tinted case. Remove the white sleeve from wires and the light.
  6. West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Find a black box directly underneath the light. Follow a black wire that connects to a metal strip.
    • The metal strip is attached to the rest of the piece with a black spring.
  7. West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Halberd Spudger
    $2.99
    • Insert the metal spudger between the metal strip and the metal pot.
    • Use the black Halberd spudger to latch onto the spring, removing it from the metal strip. When the spring is disconnected the metal strip will lift up from the pot.
  8. West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the metal strip from around the pot.
    • One side should be attached to two black wires and a blue wire.
    • The other side of the metal strip will be attached to one black wire and the spring.
  9. West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the metal spudger, go along the outside of the metal strip, propping up the metal foil and removing it from the strip.
    • A metal spudger may cause aesthetic damage to the device.
  10. West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This will leave you with a long strip of metal foil that can be completely removed from the device. Once removed, there will be three strips of sheet mica, with one strip with wire wrapped around it, inside.
  11. West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the left side of the strip, two black wires will connect at the end from the black switch. Then a blue wire from the switch will connect a quarter of the way through the strip. The inside shows the wrapping of the wire.
  12. West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The right side of the strip will have a black wire connected from the switch. This wire will wrap around the sides of the sheet as shown.
  13. West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 West Bend Crockery Cooker 84356 Disassembly: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now that the device is disassembled here is a quick explanation of how the device works.
    • Electricity flows from the 120 V AC outlet. The power source is connected to three wires, the yellow wire, black wire and white wire.
    • The yellow wire connects directly to the switch. The white wire connects to the light, and then into the switch. The black wire also connects from the power source to the switch.
    • From the switch there are two black wires and a blue wire that are leaving on the left side. On the right side there is another black wire that leaves the switch.
    • The temperature settings control which wires current will flow through during the cooking process.
    • If the Keep Warm setting is turned on the switch, current will flow through the blue wire around the strip.
    • If the LO setting is turned on the switch, current will flow through the black wires around the switch.
    • If the HI setting is turned on the switch, current will flow through both the black and blue wires.
crwdns2935103:0crwdne2935103:0
Addy Carson
crwdns2935283:009/14/22crwdne2935283:0
267 crwdns2915208:0crwdne2915208:0
Tufts University School of Engineering, Team 1-1, Bell Fall 2022 crwdns2935289:0Tufts University School of Engineering, Team 1-1, Bell Fall 2022crwdne2935289:0
TUFTS-BELL-F22S1G1
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 671
