Wen 2307 Speed Adjustment Assembly Replacement
  1. Wen 2307 Speed Adjustment Assembly Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the locking sleeve.
  2. Wen 2307 Speed Adjustment Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hanging clip.
  3. Wen 2307 Speed Adjustment Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wen 2307 Speed Adjustment Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the six 8mm PH2 screws.
  4. Wen 2307 Speed Adjustment Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
  5. Wen 2307 Speed Adjustment Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the front panel, pry the device apart while holding the device with the other hand.
    • The front panel should come out easily.
  6. Wen 2307 Speed Adjustment Assembly Replacement, Power Cable: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wen 2307 Speed Adjustment Assembly Replacement, Power Cable: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Identify the screws.
    • Unscrew the two 3mm phillips PH2.
    • Don't forget to put them appart from the ones unscrewed before.
    • Phillips PH2
    • Flathead 2.5mm
  7. Wen 2307 Speed Adjustment Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the place boar carefully.
  8. Wen 2307 Speed Adjustment Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the power cable connectors.
  9. Wen 2307 Speed Adjustment Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the cord sleve for the new cable replacement.
  10. Wen 2307 Speed Adjustment Assembly Replacement, Speed Adjustment Assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the connected wiring from the circuit board.
  11. Wen 2307 Speed Adjustment Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 4mm screw retaining the circuit board.
  12. Wen 2307 Speed Adjustment Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry the circuit board from the back piece.
Dominick Chavez
crwdns2935283:002/08/16crwdne2935283:0
137 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 12-1, Eyestone Spring 2016 crwdns2935289:0USF Tampa, Team 12-1, Eyestone Spring 2016crwdne2935289:0
USFT-EYESTONE-S16S12G1
crwdns2942667:0crwdne2942667:0 873
