If the device is not changing speed it may be because of a broken speed adjuster.
Unscrew the locking sleeve.
While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
To remove the front panel, pry the device apart while holding the device with the other hand.
Identify the screws.
Unscrew the two 3mm phillips PH2.
Phillips PH2
Flathead 2.5mm
Pull out the cord sleve for the new cable replacement.
Remove the connected wiring from the circuit board.
Remove the single 4mm screw retaining the circuit board.
Gently pry the circuit board from the back piece.
