Weinmann VENTImotion and VENTIlogic Fascia Film Replacement
  1. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement, Fascia Film: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the device
    • 1.Place the device on a non-slip surface with the top facing downwards
    • 2.Remove the filter cassette from the top part of the housing.
    • 3.Undo and remove the 6 screws (34)
  2. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the mains supply unit
    • Disconnect the power board/mains supply unit connecting cable (45) from the power board.
    • Slightly lift mains supply unit (44) and disconnect the mains input connector from the mains supply unit (44).
    • Lift the mains supply unit out of the top part of the housing.
    • Disconnect the power board/mains supply unit connecting cable from the mains supply unit.
  3. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove box and filter holder
    • Release the pressure-side hose (74) from the box.
    • Lift box (58) and filter holder (37) out of the top part of the housing together.
    • Disconnect the box and the filter holder from one another by undoing the intake-side hose (73) from both parts.
  4. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  5. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel the protective film off the inside of the new fascia film and affix fascia film (33) to this area of the housing.
    • Ensure that the ribbon cable is pushed cleanly through the opening in the housing without any kinks.
    • Carefully pull the outer protective film off the new fascia film using a fingernail.
  6. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Refit the box and filter holder.
    • Connect the box and the filter holder to one another by reconnecting the intake side hose (73) from both parts.
    • Refit box (58) and filter holder (37) back on the top part of the housing together.
    • Connect the pressure-side hose (74) from the box.
  7. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Refit the mains supply unit
    • Reconnect the power board/mains supply unit connecting cable from the mains supply unit.
    • Put the mains supply unit back in the top part of the housing.
    • Reconnect the mains input connector from the mains supply unit (44).
    • Reconnect the power board/mains supply unit connecting cable (45) from the power board.
  8. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Close the device
    • Hold the bottom part of the housing (35) up to the side of the top part of the housing (36)
    • Plug the connecting cables for the humidifier (42) and the alarm (43) onto the relevant connectors.
    • Check that all hoses and cables are plugged on firmly.
    • Place the bottom part of the housing (35) on the top part of the housing (36). Ensure that no cables or hoses are trapped or bent.
    • Now screw the top part of the housing tight using the 6 screws (34).
    • Then turn the device back over
Jay Vidinoff
crwdns2935283:004/07/20crwdne2935283:0
610 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G19, Paton Spring 2020 crwdns2935289:0Cal Poly, Team S7-G19, Paton Spring 2020crwdne2935289:0
CPSU-PATON-S20S7G19
crwdns2942667:0crwdne2942667:0 185
