Waterlogged Samsung Galaxy Grand Prime
  1. Waterlogged Samsung Galaxy Grand Prime, Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime, Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off your waterlogged Samsung Galaxy Grand Prime to prevent potential damage to the running circuitry
    • Place the phone with its screen facing the work surface
  2. Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position the primary back panel towards you
    • Detach the primary back panel to expose the battery in the secondary back panel
  3. Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a 1.5x25 millimeter Phillips head screwdriver, remove the nine 4mm screws to gain access to the inner circuitry.
    • Put the screws to the side in order to avoid misplacement
  4. Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery to prevent damage during the process
    • Gently peel up the battery and set it aside
  5. Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully peel away the screen display from the secondary back panel
    • Use a hair dryer if needed to soften adhesive
  6. Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Address areas of concern in the main frame with a small towel or cotton swab
    • Submerging both parts in a container of desiccants like silica gel for a period of time can also be another option
  7. Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure that there is no remaining liquid
    • Reassemble the phone, starting with the screen and secondary back panel
    • Press in on every side until the frame clicks into place
  8. Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Retrieve the battery set aside in step 4
    • Orient it correctly so the phone can properly boot up later
    • Carefully place the battery back into its slot
  9. Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Retrieve all of the 4mm screws you put aside in Step 3
    • Using the 1.5x25 millimeter Phillips head screwdriver, tighten all 9 of the 4mm screws
    • Confirm that each screw is sufficiently tightened to ensure stability and proper function
  10. Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Bring back the primary back panel from step 2
    • Align the primary back panel with the secondary back panel, ensuring the Samsung logo is facing outward
    • Click the panels together and work your way around until all sides are securely attached
  11. Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Waterlogged Samsung Galaxy Grand Prime: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Charge the phone with a USB Micro-B cable so it has an initial charge when opening it back up
    • When all steps are performed correctly, the phone should power up and work as intended
Johny Vu
crwdns2935283:010/24/23crwdne2935283:0
241 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 9-7, Ribeiro Fall 2023 crwdns2935289:0CSU Los Angeles, Team 9-7, Ribeiro Fall 2023crwdne2935289:0
CSULA-RIBEIRO-F23S9G7
crwdns2942667:0crwdne2942667:0 518
