Water Dancing Speakers Refill
  1. Water Dancing Speakers Refill, Water plug & water: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Water Dancing Speakers Refill, Water plug & water: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You will need to have a clean work space, water dancing speakers, super glue, mineral water, and Phillips screw driver ready.
    • Unplug the USB cable powering your speakers before you continue.
  2. Water Dancing Speakers Refill: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the phillips screw driver remove the 4 screws seen on the back of speakers.
  3. Water Dancing Speakers Refill: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the four screws are taken out you will need to slide the bottom piece from the water canister.
    • When the two are separated set the water canister bottom facing up.
  4. Water Dancing Speakers Refill: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Water Dancing Speakers Refill: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the bottom of the water canister you will see a hole where the water was inserted. There will be a black plug covering the hole.
    • Using your screw driver you can pry the plug out.
    • Once the plug is taken out you can refill the speakers. Only refill the speakers with one inch of water.
  5. Water Dancing Speakers Refill: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the water is filled to approximately one inch. Super glue the hole shut and let dry.
  6. Water Dancing Speakers Refill: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When the glue is dry slide speaker back on to water canister.
    • Once they are put together place back panel on and insert the four screws.
    • repeat steps 2 through 6 on second speaker.
Your water dancing speakers are now ready for use. Thank you for using this guide.
crwdns2935229:048crwdne2935229:0
Andrew
crwdns2935283:002/17/15crwdne2935283:0
1,387 crwdns2915208:0crwdne2915208:0
crwdns2947412:036crwdne2947412:0
the pump is defective how to replace
anpicard@videotron.ca
andrepicard2012 - crwdns2934203:0crwdne2934203:0
I couldnt get plug out either so I drilled a hole in back and filled it with mineral water and sealed it with a small strip of scotch tape and duct tape on top of that in case I had to get back in. It works, but now it looks different. Sometimes the water clings to the inside and it looks a little foggy. Is it mineral water, or mineral oil? If it leaks again I'll prob try the oil.
Lacepage - crwdns2934203:0crwdne2934203:0
The original liquid has a lower surface tension than water. I used odorless mineral spirits.
If the pump is noisy, try a drop of oil in the motor.
aeromojito - crwdns2934203:0crwdne2934203:0
My speakers keep spraying even though their is no music playing, is that a good thing?
Andrew - crwdns2934203:0crwdne2934203:0
That means that the speakers are broken. You might need to replace it. If not, then its a probelm with the board, which I have no idea how to fix.
Skittlekingthefirst -
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 104
crwdns2936753:030crwdne2936753:0 365
crwdns2942667:0crwdne2942667:0 170,619
