WarioWare: Twisted! Rumble Motor Replacement
  1. WarioWare: Twisted! Rumble Motor Replacement, Rumble Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WarioWare: Twisted! Rumble Motor Replacement, Rumble Motor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Tri-point Y0 screwdriver to remove the single 3 mm screw located at the back of the game.
    • Remove the cover to expose the control module electronics board underneath.
  2. WarioWare: Twisted! Rumble Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WarioWare: Twisted! Rumble Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WarioWare: Twisted! Rumble Motor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Heat up the soldering iron to approximately 350 degrees Fahrenheit.
    • Remove the rumble motor from the slot.
    • For more information on soldering, refer to How to Solder and Desolder Connections.
    • Apply the tip of the soldering iron to the connection points, causing the red and blue wires to melt and detach.
    • Separate the old rumble motor from the board and set it aside.
    • The soldering iron will be very hot. Do not touch the tip of the iron. It will cause severe burns.
  3. WarioWare: Twisted! Rumble Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WarioWare: Twisted! Rumble Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WarioWare: Twisted! Rumble Motor Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your hands to remove the black sleeve from the old rumble motor.
    • Set the old rumble motor aside.
    • Use your hands to place the black sleeve onto the new rumble motor you're using.
  4. WarioWare: Twisted! Rumble Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WarioWare: Twisted! Rumble Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WarioWare: Twisted! Rumble Motor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the red wire onto the plus (left) side, and the blue wire onto the minus (right) side.
    • To reattach the red and blue wires, carefully bring the tip of the soldering iron into contact with the connection points.
    • The soldering iron will be hot. Do not touch the tip of the iron.
    • Place the new rumble motor back in its slot.
    • Turn off the soldering iron after you finish this step.
  5. WarioWare: Twisted! Rumble Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WarioWare: Twisted! Rumble Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WarioWare: Twisted! Rumble Motor Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put the cover back on the game.
    • Gently push the two sides back together.
  6. WarioWare: Twisted! Rumble Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WarioWare: Twisted! Rumble Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Tri-point Y0 screwdriver to screw the single 3 mm screw back into place.
    • Test the game to make sure the problem is fixed and you should be ready to play!
I hope this guide solved your problem, and your game should work like new again!
Brent Thompson
crwdns2935283:006/21/23crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 4-7, Watkins Summer 2023 crwdns2935289:0Austin Community College, Team 4-7, Watkins Summer 2023crwdne2935289:0
AUSTINCC-WATKINS-SU23S4G7
Nice post and please provide more information. Thanks for sharing.
cunez - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 1,455
