Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement
  1. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • The screws in the rubber legs of the burner do not need to be removed.
    • If the back panel has never been opened before, the screws may be more difficult to unscrew.
  2. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a wrench, remove the bolt from the center of the back panel.
  3. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The back panel can now be easily lifted off.
  4. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement, Plastic Leg and Rubber Stoppers: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement, Plastic Leg and Rubber Stoppers: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While using the wrench to hold the bolt, use the screwdriver to remove the screw.
    • The leg is two separate pieces, the plastic leg and rubber stopper.
    • Careful not to lose the bolts and washers as they are very small.
Sun Fai Lau
crwdns2935283:009/22/14crwdne2935283:0
588 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 10-7, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 10-7, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S10G7
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 267
